Position control example
using SimpleFOCMini
For more information about the SimpleFOCMini check the docs. Currently, there are two versions of the SimpleFOCMini board available v1.0 and v1.1. The main difference between the two versions is the order of the pins. This example can be used with both versions of the board, however there are slight differences in the pinout.
Choose your SimpleFOCMini version:
SimpleFOCMini V1.0 SimpleFOCMini V1.1
- Channels
A
andB
are connected to the Arduino UNO pins2
and3
a
,b
andc
are connected directly the motor terminal connector connectorsM1
,M2
andM3
SimpleFOCMini v1.0
- The most convenient way of plugging the SimpleFOCMini v1.0 board to the Arduino UNO is to stack it on its pins
8-12
.GND
-12
IN1
-11
IN2
-10
IN3
-9
EN
-8
Pin
12
is not a real ground pin. As no power is transferred through the mini’sGND
pin then we can use pin12
to approximate theGND
pin by declaring it as digital output and setting it toLOW
. This technique might not always work though. If you start seeing that your motor vibrates, even in the open loop control mode, then you should ditch this approach and connect the mini’sGND
pin to the Arduino UNO’sGND
pin. The vibrations should then stop completely.
SimpleFOCMini v1.1
- The most convenient way of plugging the SimpleFOCMini v1.1 board to the Arduino UNO is to stack it on its pins
9-12
.GND
-GND
EN
-12
IN3
-11
IN2
-10
IN1
-9
Small motivation :D
Let’s go through the full code for this example and write it together. First thing you need to do is include the SimpleFOC
library:
Encoder code
First we define the Encoder
class with the A and B channel pins and number of impulses per revolution.
// define Encoder
In the setup()
function we initialize the encoder and enable interrupts:
For more configuration parameters of the encoders please check the Encoder
class docs.
Motor code
First we need to define the BLDCMotor
class with the number od pole pairs (11
// define BLDC motor
If you are not sure what your pole pairs number is please check the find_pole_pairs.ino
example.
Next we need to define the BLDCDriver3PWM
class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 10, 11, 12);
BLDCDriver3PWM driver = BLDCDriver3PWM(11, 10, 9, 8);
Then in the setup()
we configure first the voltage of the power supply if it is not 12
Volts and init the driver.
// power supply voltage
// default 12V
Additionally we add the code to declare the pin 12
ad digital output set to LOW
to be used as a common ground signal. In the setup
we add
pinMode(12,OUTPUT); // declares pin 12 as output and sets it to LOW
Then we tell the motor which control loop to run by specifying the motor.controller
variable.
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.02;
// angle P controller
// default P=20
// default 20
motor.velocity_limit = 4;
The last peace of code important for the motor is of course the FOC routine in the loop
function.
// iterative FOC function
For more configuration parameters and control loops please check the BLDCMotor
class doc.
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change position/angle target value in real time.
// init BLDC motor
// init driver
// init encoder
void onTarget(char* cmd){ command.motion(&motor, cmd); }
// default 12V
// default P=20
// default 20
command.add('T', doTarget, "motion control");
// function calculating the outer position loop and setting the target position
// commander interface with the user
commander.run();
// init BLDC motor
// init driver
// init encoder
// default 12V
// default P=20
// default 20
commander.run();
