Low pass filter configuration using the Commander
When using a standard callback for LowPassFilter class:commander.lpf(&lpf,cmd) the user will have available a command:
  • F: Low pass filter time constant
For example if you have a low pass filter added to the commander:
LowPassFilter filter = ....
Commander commander = ...
void onLpf(char* cmd){ commander.lpf(&filter,cmd); }
  commander.add('A',onLpf,"my lpf");
  commander.run();
You will be able to configure (set and get) its parameters from serial monitor:
$ AF           # get time constant
Tf: 1.0
$ AF0.05       # set time constant
Tf: 0.05
$ AW           # unknown command
err
