Position control example
using SimpleFOCMini
For more information about the SimpleFOCMini check the docs. Currently, there are two versions of the SimpleFOCMini board available v1.0 and v1.1. The main difference between the two versions is the order of the pins. This example can be used with both versions of the board, however there are slight differences in the pinout.
Choose your SimpleFOCMini version:
SimpleFOCMini V1.0 SimpleFOCMini V1.1
  • Channels A and B are connected to the Arduino UNO pins 2 and 3.
  • Motor phases a, b and c are connected directly the motor terminal connector connectors M1, M2 and M3 of the SimpleFOCMini board
SimpleFOCMini
  • The most convenient way of plugging the SimpleFOCMini board to the Nucleo board is to stack it on its pins 10-13.
    • GND - GND
    • IN1 - 13
    • IN2 - 12
    • IN3 - 11
    • EN - 10
    • GND - GND
    • EN - 13
    • IN3 - 12
    • IN2 - 11
    • IN1 - 10
Encoder code
// define Encoder
Motor code
First we need to define the BLDCMotor class with the number od pole pairs (11)
// define BLDC motor
Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(13, 12, 11, 10);
BLDCDriver3PWM driver = BLDCDriver3PWM(10, 11, 12, 13);
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.02;
// angle P controller
// default P=20
//  maximal velocity of the position control
// default 20
motor.velocity_limit = 4;
// iterative FOC function
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change position/angle target value in real time.
// init BLDC motor
// init driver
//  init encoder
void onTarget(char* cmd){ command.motion(&motor, cmd); }
  // default 12V
  // default P=20
  // default 20
  command.add('T', doTarget, "motion control");
  // function calculating the outer position loop and setting the target position
  // commander interface with the user
  commander.run();
// init BLDC motor
// init driver
//  init encoder
  // default 12V
  // default P=20
  // default 20
  commander.run();
