β˜… Loading...
Getting Started Guides
Here is an attempt to guide you through testing and configuring your motor control system step-by-step. It is designed to be practical and fast - you should be able to get a working motor control system in around an hour by following these steps. Each step is self-contained and testable, guiding you through the configuration, expected behavior, and troubleshooting. And if you want to go further, there are clear next steps based on your hardware setup.
Before You Start
No position sensor?
These guides assume a position sensor. Without one, you have two options:
  • Open-loop control: works with any driver, but is inefficient and can lose steps under load. Do steps 2 and 3 below.
  • Sensorless FOC: if you have current sensing, a flux observer estimates the rotor angle from the phase currents. Efficient, but only works at medium and high speeds. Do steps 2 and 3 below, then follow the sensorless guide.
Foundation Steps (All Users)
Follow these 4 guides in order. Each takes 10-15 minutes and builds on the previous one:
Step 1: Test your sensor
1. Test Your Sensor
~10 min - Validate that your position sensor is working
➜ Output angle and velocity values in serial monitor
2. Test Your Driver
~10 min - Verify motor driver can output PWM signals
➜ See β€œDriver ready!” message, no motors spinning yet
3. Motor + Driver Test (Open-Loop)
~15 min - Test motor and driver together
➜ Motor spins, you discover correct pole pair count
4. Closed-Loop Control (Voltage-Based Torque)
~15 min - First closed-loop FOC using sensor feedback
➜ Closed loop torque control working, motor follows torque/velocity/angle targets
For many users the foundation steps are all you need to get a working motor control system. Voltage mode is not the most efficient or precise control method, but it is simple and works with most motors.
Read more about voltage-based torque control Read more about motion control
Advanced Steps (Optional)
If you want to go further and use more advanced current-based torque control, follow the next steps based on your hardware.
A. Estimated Current Control (No Current Sensing)
Benefits:
  • True torque control without current sensors
  • Higher speeds and higher torques than voltage mode
  • Good for budget builds or simple applications
Requirements:
  • No current sensing hardware required
  • Motor parameters (resistance, inductance, flux) must be measured or estimated
Read more about estimated current control
B. FOC Current Control (With Sensors)
Benefits:
  • Most precise torque control available in SimpleFOClibrary
  • Hardware current feedback
  • No model parameter needed
Requirements:
  • Current sensing hardware (inline or lowside)
Read more about FOC torque control
Full Reference Documentation
Once you’re done with this getting started guide, see:
Table of contents
