I2C Magnetic sensor setup
Step 1. Instantiate MagneticSensorI2C class
Now in order to use your I2C magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorI2C class:
// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
//  chip_address         - I2C chip address
//  bit_resolution       - resolution of the sensor
//  angle_register_msb   - angle read register msb
//  bits_used_msb        - number of used bits in msb register
MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0x0E, 4);
The parameters of the class are:
  • chip_address - I2C address of the magnetic sensor
  • bit_resolution - resolution of your sensor (number of bits of the sensor internal counter register) and your
  • angle_register_msb - register number containing the MSB part of the angle value. ( ex. AS5600 - 0x0E, AS5048 - 0xFE )
  • bits_used_msb - number of used bits in MSB register
How to find the MSB register values and used bits value?
Since I2C registers are Byte(8-bit) registers they contain the 12-14 bit angle representation separated in two Byte addresses, MSB(most significant byte) and LSB(least significant byte). To instantiate the I2C magnetic sensor you need to provide the MSB register address and tell the library how is the angle value separated in the two registers. By specifying the number of bits used in the MSB register and specifying the bit_resolution value the library can calculate how many bits are used in the LSB register and can reconstruct the complete angle value.
Example MSB/LSB division:
  • AS5600 (12 bit) - MSB (4bit), LSB (8bit)
  • AS5048B (14bit): - MSB (8bit), LSB(6bit)
AS5600 example
  • First we open AS5600 sensor's datasheet .
  • In the datasheet we find the table of I2C registers (page 18)
  • The angle_register_msb value is the first (upper in datasheet) register value - 0x0E
  • The bits_used_msb value is number of bits in the MSB register - 4
Finally, after the configuration, you just call the init() function. This function prepares the I2C interface and configures the sensor hardware. So your magnetic sensor initialization code will look like:
If you wish to use more than one magnetic sensor using an I2C interface, make sure your sensors have different addresses, here is a simple example:
MagneticSensorI2C sensor1 = MagneticSensorI2C(0x36, 12, 0x0E, 4);
MagneticSensorI2C sensor2 = MagneticSensorI2C(0x37, 12, 0x0E, 4);
Multiple I2C busses
Additionally, the library enables you to already configured I2C bus to the sensor using the init() function.
Wire.setClock(400000);
Wire.begin();
// providing
sensor.init(&Wire)
For microcontrollers where that is possible (not for Arduino UNO) you can use different I2C busses for multiple I2C sensors. See the examples in utils > sensor_test > magnetic_sensors > magnetic_sensor_i2c_dual_bus_examples.
For the most common I2C magnetic sensors, the library provides the simplified configuration constructor. Namely for AS5600 12-bit sensor and AS5048 14-bit sensor.
// instance of AS5600 sensor
MagneticSensorI2C sensor2 = MagneticSensorI2C(AS5600_I2C);
// instance of AS5048B sensor
MagneticSensorI2C sensor2 = MagneticSensorI2C(AS5048_I2C);
struct MagneticSensorI2CConfig_s  {
  int chip_address;
  int bit_resolution;
  int angle_register;
  int data_start_bit;
// configuration for AS5600 sensor
MagneticSensorI2CConfig_s MySensorConfig = {
  .chip_address = 0x36,
  .bit_resolution = 12,
  .angle_register=0x0E,
  .data_start_bit=11
MagneticSensorI2C sensor = MagneticSensorI2C(MySensorConfig);
Please check the magnetic_sensor_i2_example.ino example for a quick test of your sensor. All the features of I2C magnetic sensors are implemented in the MagneticSensorI2C.cpp/h files.
Step 2. Using magnetic sensor in real-time
  • As a motor position sensor for FOC algorithm
  • As a standalone position sensor
To use the sensor with the FOC algorithm implemented in this library, once when you have initialized sensor.init() you just need to link it to the BLDC motor by executing:
And you will be able to access the angle and velocity of the motor using the motor instance:
motor.shaft_angle; // motor angle
motor.shaft_velocity; // motor velocity
or through the sensor instance:
sensor.getAngle(); // motor angle
sensor.getVelocity(); // motor velocity
Example code
Here is a quick example for AS5600 magnetic sensor with a BLDC motor and driver:
// motor and driver
// as5600 sensor quick config
MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
  // driver
  driver.init()
  // init motor hardware
  Serial.println("Motor ready");
class MagneticSensorI2C{
Calling getVelocity multiple times
When calling getVelocity it will only calculate the velocity if the elapsed time from the previous call is longer than the time specified in teh variable min_elapsed_time (default 100us). If the elapsed time from the last call is shorter than min_elapsed_time the function will return previously calculated value. Variable min_elapsed_time can be changed easily if necessary:
sensor.min_elapsed_time = 0.0001; // 100us by default
Example code
Here is a quick example for AS5600 magnetic sensor with I2C communication:
MagneticSensorI2C as5600 = MagneticSensorI2C(0x36, 12, 0x0E, 4);
// or quick config
MagneticSensorI2C as5600 = MagneticSensorI2C(AS5600_I2C);
  as5600.init();
  Serial.println("AS5600 ready");
  // update the sensor values
  as5600.update();
  Serial.print(as5600.getAngle());
  Serial.println(as5600.getVelocity());
