SPI Magnetic sensor setup
Step 1. Instantiate MagneticSensorSPI class
In order to use your SPI magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorSPI class:
// MagneticSensorSPI(int cs, float _cpr, int _angle_register, long _clock_speed)
//  cs              - SPI chip select pin
//  bit_resolution - magnetic sensor resolution
//  angle_register  - (optional) angle read register - default 0x3FFF
//  clock_speed      - (optional) SPI clock speed - default 1MHz
MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF, 1000000);
  • chip_select - pin number you connected your sensor to be used with the SPI communication,
  • bit_resolution - resolution of your sensor (number of bits of the sensor internal counter register) and your
  • angle register - register number containing angle value.
    The default angle_register number is set to 0x3FFF as it is the angle register for most of the low cost AS5048/AS5047 sensors.
  • clock_speed - speed of the SPI clock signal, default is 1MHz, but you can set it to any value supported by your sensor and microcontroller.
Which clock speed to set?
Clock speed is an important parameter for the SPI communication. It determines how fast the data is transferred between the sensor and the microcontroller. The rule of thumb is that the faster the clock speed the better FOC performance.
However, the clock speed should not be set higher than the maximum clock speed supported by the sensor and the microcontroller. Maximum clock speed supported by the sensor can be found in the sensor datasheet. If you are not sure about the maximum clock speed supported by your sensor, it is recommended to start with a low value (default 1MHz) and increase it later if necessary. Please note that the maximum clock speed supported by the sensor can be lower in practice due to the quality of the wiring and the length of the wires. If you experience communication issues with your sensor, try lowering the clock speed.
Additionally the library allows you to configure SPI communication clock speed and SPI mode by setting the variables:
// spi mode (phase/polarity of read/writes) i.e one of SPI_MODE0 | SPI_MODE1 (default) | SPI_MODE2 | SPI_MODE3
sensor.spi_mode = SPI_MODE0;
// speed of the SPI clock signal - default 1MHz
sensor.clock_speed = 500000;
Finally after the configuration the only thing you need to do is to call the init() function. This function prepares the SPI interface and initializes the sensor hardware. So your magnetic sensor initialization code will look like:
MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
  sensor.spi_mode = SPI_MODE0; // spi mode - OPTIONAL
  sensor.clock_speed = 500000; // spi clock frequency - OPTIONAL
MagneticSensorSPI sensor1 = MagneticSensorSPI(10, 14, 0x3FFF);
MagneticSensorSPI sensor1 = MagneticSensorSPI(9, 14, 0x3FFF);
Multiple SPI busses
For the microcontrollers where that is possible, library provides you a way to provide it the SPI bus you would like it to use instead of default SPI class.
// these are valid pins (mosi, miso, sclk) for 2nd SPI bus on storm32 board (stm32f107rc)
SPIClass SPI_2(PB15, PB14, PB13);
  // init magnetic sensor
  sensor.init(&SPI_2);
For the most common SPI magnetic sensors, the library provides the simplified configuration constructor. Namely for AS5047/AS5147 14-bit SPI sensors and MA70 14-bit SSI sensor.
// instance of AS5047/AS5147 sensor
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 10);
// instance of MA730 sensor
MagneticSensorSPI sensor = MagneticSensorSPI(MA730_SPI, 10);
Optionally we can override the SPI clock speed for the quick configuration as well. This might be interesting if using default configurations provided by the library but you want to set a different SPI clock speed, here is an example:
// instance of AS5047/AS5147 sensor with custom SPI clock speed and mode
// overriding default clock speed of 1MHz to 2MHz
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 10, 2000000);
struct MagneticSensorSPIConfig_s  {
  int bit_resolution;
  int angle_register;
  int spi_mode; // default SPI_MODE0
  long clock_speed;  // default 1MHz
  int data_start_bit; // default 13
  int command_rw_bit; // default 14
  int command_parity_bit; // default 15
// 12 bit, 0x3FFF angle register, spi mode 1, 1MHz, default start bit, rw command, and parity bit
MagneticSensorSPIConfig_s MySensorConfig = {
  .bit_resolution=12,
  .angle_register=0x3FFF,
  .spi_mode=SPI_MODE1,
  .clock_speed=1000000,
  .data_start_bit=13,
  .command_rw_bit=14,
  .command_parity_bit=15
MagneticSensorSPI sensor = MagneticSensorSPI(MySensorConfig, 10);
Please check the magnetic_sensor_spi_example.ino example for a quick test of your sensor. All the features of SPI magnetic sensors are implemented in the MagneticSensorSPI.cpp/h files.
Step 2. Using magnetic sensor in real-time
  • As a motor position sensor for FOC algorithm
  • As a standalone position sensor
And you will be able to access the angle and velocity of the motor using the motor instance:
motor.shaft_angle; // motor angle
motor.shaft_velocity; // motor velocity
or through the sensor instance:
sensor.getAngle(); // motor angle
sensor.getVelocity(); // motor velocity
Example code
Here is a quick example for AS5047 magnetic sensor with a BLDC motor and driver:
// motor and driver
// as5600 sensor quick config
MagneticSensorSPI sensor = MagneticSensorSPI(AS5047_SPI, 10);
  // driver
  driver.init()
  // init motor hardware
  Serial.println("Motor ready");
class MagneticSensorSPI{
Calling getVelocity multiple times
When calling getVelocity it will only calculate the velocity if the elapsed time from the previous call is longer than the time specified in teh variable min_elapsed_time (default 100us). If the elapsed time from the last call is shorter than min_elapsed_time the function will return previously calculated value. Variable min_elapsed_time can be changed easily if necessary:
sensor.min_elapsed_time = 0.0001; // 100us by default
Example code
Here is a quick example for the AS5047U magnetic sensor with SPI communication:
// MagneticSensorSPI(int cs, float _cpr, int _angle_register)
// bit_resolution  - sensor resolution
MagneticSensorSPI as5047u = MagneticSensorSPI(10, 14, 0x3FFF);
// or quick config
MagneticSensorSPI as5047u = MagneticSensorSPI(AS4147_SPI, 10);
  as5047u.init();
  Serial.println("as5047u ready");
  // update the sensor values
  Serial.print(as5047u.getAngle());
  Serial.println(as5047u.getVelocity());
