Stepper motor control example
using the SimpleFOCShield and Stm32 Nucleo-64
For this stepper motor control example we are going to be using this hardware:
Download the STL file as well as STEP and solidworks project of the amt103 mount on the nema17 used in the images and the Youtube video here.
Here is an example of the connection scheme using the SimpleFOCShield and Nucleo-64:
Nema 17 stepper motor connection using 3 phases
As nema 17 steppers have 2 phases and 4 wires, we need to transform them to 3 phases to connect them to the SimpleFOCShield. So we will connect one wire from each phase to the shield separately and the third wire of each phase will be connected together to the common phase.
Pin Nema 17 wire Shield phase
1 A+ A
2 B-, A- B
3 B+ C
  • Motor phases A, B and common are connected directly the motor terminal connector TB_M1
It is not too important which of the two wires + or - you connect to which pin as long as the common pin 2 has the wires of both phases connected to it. If it does not the motor will not work.
SimpleFOCShield connections
Signal Pwm A Pwm B Pwm C Enable Encoder A Encoder B Encoder I Current A Current B
Pin 6 10 5 8 3 2 4 A0 A2
  • Index channel you can connect directly to the P_ENC as well to the terminal I
There are just a couple of things to note when using stepper motors in the hybrid configuration with the SimpleFOClibrary:
  • The motor is configured as a HybridStepperMotor and not a StepperMotor
HybridStepperMotor motor = HybridStepperMotor(50);
  • The driver pins order is important, it should be:
    1. A phase
    2. B phase
    3. common pin In this example we are using the BLDCDriver3PWM driver
// IMPORTANT: the order of the pins is important, it should be:
// 1. Stepper A phase (shield pin A)
// 2. Stepper B phase (shield pin C)
// 3. common pin (shield pin B)
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 5, 10, 8);
Here is the full code example for the stepper motor control using the SimpleFOCShield and Stm32 Nucleo-64:
// Stepper motor
// BLDC driver instance
// SimpleFOCShield
// inline current sensor instance
// ACS712-05B has the resolution of 0.185mV per Amp
// NOTE: LowsideCurrentSense sense is used because its faster than InlineCurrentSense class
LowsideCurrentSense current_sense = LowsideCurrentSense(185.0f, A0, A2);
//void doMotion(char* cmd){ command.motion(&motor, cmd); }
  // enable more verbose output for debugging
  driver.voltage_power_supply = 20;
  // link current sense and the driver
  // SVPWM modulation type is much more efficient for hybrid stepper motors
  motor.PID_velocity.P = 0.05f;
  motor.PID_velocity.I = 1;
  motor.PID_velocity.D = 0;
  motor.voltage_limit = 12;
  motor.LPF_velocity.Tf = 0.01f;
  // angle loop controller
  // angle loop velocity limit
  motor.velocity_limit = 20;
  // current sense init and linking
  // motor monitoring
  motor.monitor();
