DRV8302 driver with Arduino UNO
DRV8302 is a high performance BLDC driver board capable of delivering 15A current continuously and 27A peak current. It has temperature and over-current protection, it has Back EMF and three phase current sensing and last but not the least it can be run using only 3 PWM signals making it compatible with the SimpleFOClibrary.
Here is an example of the connection scheme using the Arduino UNO:
You can find this board on Aliexpress for the price of ~35$
DRV8302
- As any other BLDC driver supported with this library the board receives 3PWM signals: pwm
a,bandc. Connect them toINHA,INHBandINHC - Additionally connect the enable pin as well to
EN-GATEpin - To configure the BLDC driver we will need three pins (purple)
M_PWMwhenhighenables 3PWM mode (iflowthe board expects 6PWM signals)M_OCwhenlowenables over-current protectionOC_ADJanalog input adjusting the over-current limit - if you donβt care you can put it tohigh
- To read the fault signals we will need to read two pins (red)
nFAULTwhen inhighboard in fault statenOCTWwhen inhighover-current limit reached
- Channels
AandBare connected to the external interrupt pins2and3 - If your encoder has an
indexsignal you can connect it to any available digital pin, here we connected it to the pin4
a,bandcare connected directly the board terminalsOUTA,OUTBandOUTC
Example connection
β>
