Fabrication guide for SimpleFOCMini
The SimpleFOCMini is designed in EasyEDA, with an LCSC part number for every component, so the easiest way to make it is to order it fully assembled from JLCPCB, straight from the EasyEDA project.
Step by step guide: ordering from JLCPCB
Mini settings
| Setting | Mini v2.3 | Mini v1.1 |
| EasyEDA project | simplefocmini v2 | simplefocmini v1 |
| Editor | EasyEDA Standard | EasyEDA Standard |
| Layers | 2 | 2 |
| Assembly side | Top | Top |
| Parts to unselect in the BOM | None, all the parts are SMD | The through-hole female headers H1 and P1 |
The pin headers are not part of the assembly, solder them yourself.
The GitHub repository also has the Gerber files, the BOM and the pick and place file, if you want to order from another PCBA service.
Fully assembled boards
You can also buy the fully assembled and tested SimpleFOCMini v2.3 from Makerfabs. Unless you need several boards, itβs usually cheaper than ordering a batch from JLCPCB.
