Arduino SimpleFOClibrary Source Code v2.4.0
The library follows the standard Arduino library structure and provides FOC control for three motor types:
  • BLDCMotor: Standard 3-phase BLDC motors
  • StepperMotor: 2-phase stepper motors
  • HybridStepperMotor: 2-phase stepper motors with BLDC drivers
The codebase is organized into functional modules:
  • sensors/: Position sensors (encoders, magnetic sensors, Hall sensors)
  • drivers/: Motor drivers (3PWM, 6PWM, 2PWM, 4PWM configurations)
  • current_sense/: Current sensing implementations (inline, low-side, high-side)
  • communication/: Communication protocols (Commander, Step/Dir)
  • common/: Utility classes and base classes (PID, LPF, FOCMotor base)
The library is cross-platform and supports multiple microcontroller architectures, with hardware-specific implementations abstracted in the hardware_specific/ folders.
Library Source Structure
src/
├─ SimpleFOC.h                 # Main include file
├─ BLDCMotor.cpp/h             # BLDC motor class
├─ StepperMotor.cpp/h          # Stepper motor class
├─ HybridStepperMotor.cpp/h    # Hybrid stepper motor class
├─── common/                   # Utility classes and base classes
│    ├─ base_classes/          # Abstract base classes
│    │   ├─ FOCMotor.cpp/h     # Base motor class
│    │   ├─ BLDCDriver.h       # Base BLDC driver interface
│    │   ├─ StepperDriver.h    # Base stepper driver interface
│    │   ├─ Sensor.h           # Base sensor interface
│    │   └─ CurrentSense.h     # Base current sense interface
│    ├─ pid.cpp/h              # PID controller implementation
│    ├─ lowpass_filter.cpp/h   # Low-pass filter implementation
│    ├─ foc_utils.cpp/h        # FOC utility functions
│    └─ time_utils.cpp/h       # Time measurement utilities
├─── drivers/                  # Motor driver implementations
├─── sensors/                  # Position sensor implementations
├─── current_sense/            # Current sensing implementations
└─── communication/            # Communication protocols
For more info visit full source code documentation
Motor Classes
Base class: FOCMotor.cpp/h
Base motor class with common FOC control logic, used as a parent class for all motor types
  • Multiple torque control modes (voltage, dc_current, foc_current, estimated_current)
  • 7 motion control types (torque, velocity, angle, etc.)
  • Open-loop and closed-loop operation
  • Position sensor and current sense integration nad alignment procedures
There are three child classes that extend FOCMotor with specific implementations for different motor types:
  • BLDCMotor.cpp/h: Standard 3-phase BLDC motors
  • StepperMotor.cpp/h: 2-phase stepper motors
  • HybridStepperMotor.cpp/h: 2-phase stepper motors optimized for high pole counts
BLDCMotor.cpp/h
BLDC motor implementation for standard 3-phase brushless DC motors:
  • FOC algorithm with 4 modulation types (SinePWM, SpaceVectorPWM, Trapezoid_120, Trapezoid_150)
  • Can be paired with any position sensor and current sense implementation
  • Can be paired with any BLDC driver (3PWM or 6PWM) only
StepperMotor.cpp/h
Stepper motor implementation for standard 2-phase stepper motors:
  • FOC-based stepper control (SinePWM only)
  • Can be paired with any Stepper driver (2PWM or 4PWM) only
Hybrid stepper motor implementation for standard 2-phase stepper motors used with BLDC drivers:
  • FOC-based stepper control (SinePWM and SpaceVectorPWM)
📚 Implementation Documentation
FOC workflow Implementation Motion Control Implementation Torque Control Implementation
PID Controller Implementation Low-Pass Filter Implementation
Motor Drivers
All motor drivers are located in the drivers/ directory:
drivers/
├─ BLDCDriver3PWM.cpp/h       # 3-PWM BLDC driver (3 half-bridges)
├─ BLDCDriver6PWM.cpp/h       # 6-PWM BLDC driver (3 full H-bridges)
├─ StepperDriver2PWM.cpp/h    # 2-PWM stepper driver (1 per phase)
├─ StepperDriver4PWM.cpp/h    # 4-PWM stepper driver (2 per phase)
├─ hardware_api.h             # MCU-specific PWM configuration API
└─── hardware_specific/       # MCU-specific implementations
     └─ (various MCU implementations)
BLDC Driver Interface
All BLDC drivers implement the BLDCDriver abstract class:
class BLDCDriver {
    /** Initialize hardware */
    virtual int init();
    /** Enable driver */
    virtual void enable();
    /** Disable driver */
    virtual void disable();
    long pwm_frequency;          // PWM frequency in Hz
    float voltage_power_supply;  // Power supply voltage
    float voltage_limit;         // Maximum voltage to motor
    /** Set phase voltages to hardware */
    virtual void setPwm(float Ua, float Ub, float Uc) = 0;
    /** Set phase state (active/high-impedance) */
    virtual void setPhaseState(PhaseState sa, PhaseState sb, PhaseState sc) = 0;
enum PhaseState {
    PHASE_ON,   // Phase actively driven
    PHASE_OFF   // Phase in high-impedance (for trapezoidal commutation)
Stepper Driver Interface
And all the stepper drivers implement the StepperDriver abstract class.
class StepperDriver{
        /** Initialise hardware */
        virtual int init();
        /** Enable hardware */
        /** Disable hardware */
        long pwm_frequency; //!< pwm frequency value in hertz
        float voltage_power_supply; //!< power supply voltage
        float voltage_limit; //!< limiting voltage set to the motor
         * Set phase voltages to the hardware
         * @param Ua phase A voltage
         * @param Ub phase B voltage
        virtual void setPwm(float Ua, float Ub);
Furthermore all the supported MCU architectures with the simplefoc library have to implement the header file hardware_api.h. The off-the-shelf supported architectures will have implementation of the hardware_api.h placed in the hardware_specific folder. If you wish to implement a new MCU please do create a new instance of the my_new_mcu.cpp and implement all the functions from the hardware_api.h, or at least the ones that you need.
Position Sensors
sensors/
├─ Encoder.cpp/h              # Quadrature encoder (A/B, optional index)
├─ MagneticSensorSPI.cpp/h    # SPI magnetic sensors (AS5047, AS5048, MA730)
├─ MagneticSensorI2C.cpp/h    # I2C magnetic sensors (AS5600)
├─ MagneticSensorAnalog.cpp/h # Analog magnetic sensors
├─ MagneticSensorPWM.cpp/h    # PWM output magnetic sensors
├─ HallSensor.cpp/h           # Hall effect sensors (3-sensor commutation)
└─ GenericSensor.cpp/h        # Wrapper for custom sensor implementations
All position sensors implement the Sensor abstract class, making them interchangeable with any motor class:
class Sensor {
    /** Get current angle in radians [0, 2π] */
    virtual float getAngle() = 0;
    /** Get current angular velocity in rad/s */
    virtual float getVelocity();
    /** Check if sensor needs index search */
    virtual int needsSearch();
    /** Initialize sensor */
    virtual void init();
    /** Update sensor reading (for sensors requiring polling) */
    virtual void update();
Link a sensor to a motor:
Custom Sensor Implementation
To implement a custom sensor there are two approaches:
  • Extend the Sensor class (Advanced users only, not recommended for most users)
See a quick guide to implement your own sensor class (Advanced)
  • Implement the GenericSensor callbacks. This approach allows you to use the GenericSensor class without creating a new class (Recommended for most users)
See a quick guide how use Generic Sensor class (Recommended){.: .btn .btn-docs}
Current Sensing
current_sense/
├─ InlineCurrentSense.cpp/h       # Inline (shunt) current sensing
├─ LowsideCurrentSense.cpp/h      # Low-side current sensing
├─ GenericCurrentSense.cpp/h      # Wrapper for custom implementations
├─ hardware_api.h                 # MCU-specific ADC configuration API
└─── hardware_specific/           # MCU-specific ADC implementations
All current sense classes implement the CurrentSense interface:
class CurrentSense {
    /** Initialize ADC hardware and synchronization */
    virtual int init() = 0;
    /** Link current sense to driver (sync if needed) */
    void linkDriver(FOCDriver *driver);
    /** Read phase currents (A, B, C) */
    virtual PhaseCurrent_s getPhaseCurrents() = 0;
    /** Read total DC current magnitude (for dc_current torque mode) */
    virtual float getDCCurrent(float angle_el = 0);
    /** Read d-q currents (for foc_current torque mode) */
    DQCurrent_s getFOCCurrents(float angle_el);
    /** Align current sense with motor driver (default implementation available) */
    virtual int driverAlign(float align_voltage, bool modulation_centered = false);
    /** Enable/disable current sense (optional override) */
    /** Utility: read averaged currents */
    PhaseCurrent_s readAverageCurrents(int N = 100);
    bool skip_align = false;  // Skip alignment during initFOC()
All the current sensing implementations extend this base class, are interchangeable, and can be used with any motor type.
Current Sensing Methods
You can also create your own current sensing strategy by either:
  • Extending the CurrentSense class (Advanced users only, not recommended for most users)
See library source code for more details (Advanced)
  • Implementing the GenericCurrentSense callbacks. This approach allows you to use the GenericCurrentSense class without creating a new class (Recommended for most users)
Generic Current Sense Guide (Recommended)
Torque Control Modes
Current sensing enables advanced torque control modes:
  • dc_current: Uses getDCCurrent() - measures total current magnitude
  • foc_current: Uses getFOCCurrents() - measures d and q axis currents separately
  • estimated_current: Estimates current from voltage and motor resistance (no sensor needed)
Link current sense to motor:
Communication Protocols
communication/
├─ Commander.cpp/h          # G-code-like serial command interface
├─ commands.h               # Built-in command definitions
├─ StepDirListener.cpp/h    # Step/direction interface
└─ SimpleFOCDebug.h         # Debug output utilities
Commander Interface
The Commander class provides a powerful ASCII command interface:
  • G-code-style commands: Human-readable motor control
  • Parameter access: Runtime tuning of PID, limits, and control parameters
  • Multi-motor support: Control multiple motors from one serial interface
  • Built-in commands: For FOCMotor, PIDController, and LowPassFilter classes
Commander Interface Documentation Motor Commands Reference
Step/Direction Listener
The StepDirListener class enables standard stepper motor interfaces:
  • Step/direction protocol: Compatible with CNC controllers
  • Pulse counting: Tracks position from step pulses
  • Direction control: Responds to direction pin changes
Step/Direction Listener Documentation
Common Utilities
common/
├─── base_classes/            # Abstract base classes
│    ├─ FOCMotor.cpp/h        # Base motor class (shared by all motor types)
│    ├─ CurrentSense.h        # Base current sense interface
│    └─ FOCDriver.h           # Common driver interface
├─ foc_utils.cpp/h            # FOC algorithm utilities
├─ time_utils.cpp/h           # Time measurement and delays
└─ defaults.h                 # Default configuration parameters
Base Classes
All motors, drivers, sensors, and current sensors extend abstract base classes defined in base_classes/. This architecture ensures:
  • Interchangeable components: Any sensor works with any motor
  • Consistent interfaces: Same methods across all implementations
  • Easy extension: Add new hardware by implementing base class methods
Signal Processing Classes
PIDController (pid.cpp/h):
  • Discrete PID implementation with Tustin integration
  • Anti-windup protection via output clamping
  • Output rate limiting (ramp)
  • Used for velocity, position, and current control
PID Implementation Details
LowPassFilter (lowpass_filter.cpp/h):
  • First-order discrete low-pass filter
  • Configurable time constant (Tf)
  • Used for velocity and current filtering
LPF Implementation Details
Default Configuration
The defaults.h file defines sensible starting values:
// Power supply
#define DEF_POWER_SUPPLY 12.0           // Default voltage [V]
// Velocity PID defaults
#define DEF_PID_VEL_P 0.5               // Proportional gain
#define DEF_PID_VEL_I 10.0              // Integral gain
#define DEF_PID_VEL_D 0.0               // Derivative gain
#define DEF_PID_VEL_U_RAMP 1000.0       // Output ramp [V/s]
// Position P controller defaults
#define DEF_P_ANGLE_P 20.0              // Proportional gain
#define DEF_VEL_LIM 20.0                // Velocity limit [rad/s]
// Sensor alignment
#define DEF_VOLTAGE_SENSOR_ALIGN 3.0    // Alignment voltage [V]
#define DEF_INDEX_SEARCH_TARGET_VELOCITY 1.0  // Index search velocity
// Filtering
#define DEF_VEL_FILTER_Tf 0.005         // Velocity LPF time constant [s]
These values work well for gimbal motors but may need tuning for your specific application.
Additional Resources
Detailed explanations of key library components:
FOC Workflow Implementation Motion Control Implementation Torque Control Implementation
Examples
The library includes 88+ examples covering:
  • Hardware-specific configurations (ESP32, STM32, Teensy, SAMD, etc.)
  • Motion control modes (torque, velocity, position)
  • Current sensing and torque control
  • Communication interfaces
  • Multi-motor systems
Browse All Examples
API Documentation
Complete API reference with Doxygen:
Full API Documentation
