Velocity control example
using HMBGC V2.2 board
This is a very simple and cool example of using the FOC algorithm using the gimbal controller board. They are not meant to be used with the closed loop position control but SimpleFOClibrary makes it not just possible but also pretty simple.
Here is the hardware we used for this project:
For a bit more in depth explanation of HMBGC V2.2 connections please check the connection examples.
Pinout restriction
HMBGC doesn't have access to the Arduino's external interrupt pins 2 and 3, moreover the only pins we have access to are analog pins A0-A7. Therefore we need to read the encoder channels using the software interrupt library, please check the encoder code implementation for more information.
  • Encoder channels A and B are connected to the pins A0 and A1.
  • Motor phases a,b and c are connected directly to the driver outputs
  • Motor terminal M1 uses Arduino pins 9,10,11 and M2 uses 3,5,6
Make sure you have the library installed. If you still don’t have it please check the get started page.
Also in the case of the gimbal controllers like the HMBGC we do not have access to the hardware interrupt pins so you will need to have a software interrupt library. I would suggest using PciManager library. If you have not installed it yet, you can do it using the Arduino library manager directly. Please check the Encoder class docs for more info. So once you have it please include it to the sketch:
// software interrupt library
#include <PciManager.h>
#include <PciListenerImp.h>
Encoder code
First, we define the Encoder class with the A and B channel pins and number of impulses per revolution.
// define Encoder
Encoder encoder = Encoder(A0, A1, 2048);
Next we define the PciManager pin change listeners:
// pin change listeners
PciListenerImp listenerA(encoder.pinA, doA);
PciListenerImp listenerB(encoder.pinB, doB);
In the setup() function first we initialize the encoder:
And then instead of calling encoder.enableInterrupt() function we use the PciManager library interface to attach the interrupts.
// interrupt initialization
PciManager.registerListener(&listenerA);
PciManager.registerListener(&listenerB);
Motor code
First we need to define the BLDCMotor class with the number of pole pairs (14)
// define BLDC motor
BLDCMotor motor = BLDCMotor(14);
Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 10, 11);
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
Now we configure the PI controller parameters
// default P=0.5 I = 10
// default value is 300 volts per sec  ~ 0.3V per millisecond
motor.voltage_limit = 6;
For more information about the velocity control loop parameters please check the doc.
And finally we connect the encoder and the driver to the motor, do the hardware init and init of the Field Oriented Control.
// iterative FOC function
// iterative function setting and calculating the velocity loop
motor.move(target_velocity);
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change velocity target value in real time.
BLDCMotor motor = BLDCMotor( 14 );
// define driver
//  define Encoder
Encoder encoder = Encoder(A0, A1, 500);
// interrupt routine initialization
// encoder interrupt init
// target variable
float target_velocity=0;
void onTarget(char* cmd){ command.scalar(&target_velocity, cmd); }
  // default 12V
  // set FOC loop to be used
  command.add('T', onTarget, "target velocity");
  Serial.println("Set the target velocity using serial terminal:");
  // 0.5 hertz sine wave
  //target_velocity = sin( micros()*1e-6 *2*M_PI * 0.5 );
  // iterative function setting the velocity target
