Fabrication guide for SimpleFOCShield
Here is a quick guide how to fabricate the Arduino SimpleFOCShield check the most recent versions . Here we showcase all the major versions, from v1 to the latest v4.
Older versions
Board releases
| SimpleFOCShield v1.3 | release v1.3 | 04/20 | Inital release |
| SimpleFOCShield v1.3.1 | release v1.3.1 | 07/20 | added Nucleo stacking support |
| SimpleFOCShield v1.3.2 | release v1.3.2 | 09/20 | added I2C pullups |
| SimpleFOCShield v1.3.3 | release v1.3.3 | 12/20 | adapted L6234 circuit + full Arduino header |
| SimpleFOCShield v2.0 | release v2.0 | 01/21 | - 3A in-line current sensing - 5V regulator - new pinout for hardware config |
| SimpleFOCShield v2.0.1 | release v2.0.1 | 01/21 | - reduced via size - configurable range |
| SimpleFOCShield v2.0.2 | release v2.0.2 | 02/21 | replaced 7805(connected to 5V) with 78M08 (connected to VIN) to be compatible with stm32 Nucleo-64 |
| SimpleFOCShield v2.0.3 | release v2.0.3 | 03/21 | - Shortened the lines from ADC to current sense - Typo fix : underside label switched phase A and phase B |
| SimpleFOCShield v2.0.4 | release v2.0.4 | 09/21 | - Pullup config simplified - Max input voltage 35V - removed CAP2 for a CL1 - Easy EDA version of the project |
| SimpleFOCShield v3.1 | release v3.1 | 10/22 | - Complete redesign - Transition to DRV8313 - Transition to ACS712 - Smaller footprint: 56mm x 53mm - Fault and reset pins exposed (optional) - Fault led indication - Fully developed using EasyEDA |
| SimpleFOCShield v3.2 | release v3.2 | 04/24 | - Official release - Resolved the bug #9 |
| SimpleFOCShield v4.1 | release v4.1 | 04/26 | - Official v4 release - Transition to DRV8316 - Transition to INA240 amplifiers - Power supply voltage sensing - QWIIC/STEMMA QT and SPI JST connectors |
Fully assembled versions
