- Writing the code
- Before you start
- Choose your sensor
- Step 1. Test the driver in open loop
- Step 2. Test the sensor
- Step 3. Close the loop
- Step 4. Current sensing and FOC current control
- Step 5. Power supply voltage sensing (v4 only)
- Step 6. Control the motor from your computer
- Full code
- Using a stepper motor
- Going further
Writing the code
This guide takes you from a fresh SimpleFOCShield to a motor running with FOC current control, one step at a time. Each step adds a piece of code and checks that it works before moving on, so if something goes wrong you know exactly where.
The guide is written for the SimpleFOCShield v4. The code is the same for v3, except for the current sensing; the differences are shown in boxes like this one:
v3
Differences for the SimpleFOCShield v3 are shown in these boxes.
Before you start
- The solder pads are configured: PWM, enable, sensor and current sense pins
- VDD is set to match your microcontroller: 5V for Arduino UNO, 3.3V for STM32 Nucleo and ESP32
- The motor, power supply and sensor are connected
- The SimpleFOClibrary is installed
The code is written for a BLDC motor; using a stepper motor needs only a few changes, see using a stepper motor.
The code in this guide uses the suggested single-board pinout. If you soldered different pads, change the pin numbers in the code:
| Signal | PWM A | PWM B | PWM C | Enable | Enc. A / Hall U | Enc. B / Hall V | Enc. I / Hall W | Current 1 | Current 2 | Voltage |
| Pin | 6 | 10 | 5 | 8 | 3 | 2 | 4 | A0 | A2 | A3 |
Arduino UNO or a bigger board?
The Arduino UNO can run steps 1 to 4: open loop, sensor and closed-loop voltage control. FOC current control (step 5) and the full web controller interface (step 7) don’t fit in its 32kB of flash, so for those use a board such as an STM32 Nucleo-64 or an ESP32. The full code section has a version for each.
Choose your sensor
The Shield supports encoders, SPI and I2C magnetic sensors, and Hall sensors. Pick yours, and all the code on this page will follow your choice:
Encoder SPI magnetic sensor I2C magnetic sensor Hall sensors
The encoder is connected to the P_ENC header: channels A and B on pins 3 and 2, the interrupt pins of the Arduino UNO. Set the pulses per revolution (PPR) of your encoder, 2048 here.
// encoder on P_ENC: A, B, pulses per revolution
Encoder sensor = Encoder(3, 2, 2048);
void doA() { sensor.handleA(); }
void doB() { sensor.handleB(); }
First check that the driver and the motor work, without the sensor. This code spins the motor in open loop at one turn per second:
BLDCMotor motor = BLDCMotor(7); // pole pairs
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5, 8); // PWM A, B, C, enable
driver.voltage_power_supply = 12; // your supply voltage
motor.voltage_limit = 2; // keep it low: open loop has no current control
motor.target = 6.28; // rad/s, one turn per second
Upload it and open the serial monitor at 115200 baud. The motor should spin smoothly. Send T-6.28 to reverse, or T0 to stop.
- The motor doesn’t move: check the enable pin. The driver stays off until the enable pin is high, so it must be soldered and match the code.
- The motor vibrates but doesn’t turn: one phase is not connected, or a PWM pin in the code doesn’t match the solder pads.
- The motor gets hot: lower
motor.voltage_limit. In open loop the motor draws current all the time, even without load. Stepper motors have a low resistance, so start with avoltage_limitof about 1V for them.
Read more about the open-loop test
Next check that the sensor reads the position correctly:
sensor.enableInterrupts(doA, doB);
delay(10);
Turn the motor by hand. The angle (in radians) should change smoothly, by 6.28 per full turn, and the velocity should be close to zero at rest.
- The angle doesn’t change: wrong pins or wrong sensor type in the code, or the sensor is not powered (check VDD).
- The angle jumps or is noisy: for encoders and Hall sensors, enable the pull-ups; for magnetic sensors, check the magnet distance and centring.
- The angle changes less than 6.28 per turn: wrong PPR for the encoder, or wrong pole pairs for the Hall sensors.
Read more about testing the sensor
Now put the two together. Link the sensor to the motor, switch to torque control with voltage, and call initFOC() to align the sensor with the motor:
// in setup(), after the sensor and driver init
motor.voltage_limit = 6; // Volts
motor.initFOC(); // aligns the sensor, the motor moves a bit
// in loop()
During initFOC() the motor moves slightly in both directions, and the debug output on the serial monitor shows the result of the alignment. Then set a target voltage, e.g. T2: the motor should accelerate smoothly and reach a speed that depends on the voltage. A negative target reverses the direction.
initFOC()fails with a “pole pairs” or “no movement” message: wrong pole pairs, or the sensor doesn’t work (go back to step 2).- The motor spins well in one direction but not the other, or vibrates: try a lower
motor.voltage_limitfor the alignment, and check that the sensor is fixed firmly to the motor.
Once this works, you can try velocity or angle control by changing motor.controller, see motion control.
Read more about closing the loop
With current sensing, the motor’s torque is controlled directly as a current, which makes the control much more precise and protects the motor and the driver. The v4 has inline current sensing with INA240A2 amplifiers (gain 50) and 5mΩ shunt resistors:
// shunt resistor [Ω], amplifier gain, current sense pins (phase A, B, C)
InlineCurrentSense current_sense = InlineCurrentSense(0.005f, 50.0f, A2, _NC, A0);
// in setup(), after driver.init() and before motor.init()
motor.current_limit = 2; // Amps
The target is now in Amps: T0.5 applies 0.5A. During initFOC(), the library also checks which current sense pin belongs to which phase and the sign of the measurement, and corrects them automatically if needed.
v3
The v3 has ACS712 Hall current sensors with 185mV/A:
InlineCurrentSense current_sense = InlineCurrentSense(185.0f, A0, A2);
Tip: use the low-side current sensing class if your MCU supports it
The Shield has inline current sensing, but its amplifiers measure the current all the time, so it can also be read with the
LowsideCurrentSenseclass. Just change the class name, the arguments stay the same:LowsideCurrentSense current_sense = LowsideCurrentSense(0.005f, 50.0f, A2, _NC, A0);
LowsideCurrentSensesamples the currents in hardware, synchronised with the PWM, instead of reading them withanalogRead()in everyloopFOC()call. This makes the FOC loop much faster and the measurements less noisy. It is supported on STM32 (F1, F4, G4, L4, F7, H7), ESP32 with MCPWM and SAMD21, but not on the Arduino UNO, see the supported MCUs.
Tune the current controller automatically
The current controller needs PI gains that match the motor. The library can measure the motor resistance and inductance and calculate them for you. Add this after motor.initFOC():
motor.tuneCurrentController(300.0f); // current loop bandwidth in Hz
If the motor resistance and inductance are not set, it first measures them with characteriseMotor(). The gains are printed to the serial monitor; write them down and set them in your code (motor.PID_current_q.P, motor.PID_current_q.I, and the same for PID_current_d) so you don’t need to measure on every startup. Keep the bandwidth well below the rate at which loopFOC() runs, about 5-10% of it. For a fixed, known loop rate, run the FOC loop from a timer, see the real-time loop guide.
Read more about current control Tuning the current loop
If you soldered the voltage sensing pad, the board measures the supply voltage divided by 11. Use it to set the driver’s supply voltage automatically, so the voltages the library applies are correct even when the supply changes, e.g. with a battery:
// supply voltage sensing: VCC/11 on A3
float readSupplyVoltage() {
// ADC reference voltage / ADC resolution * divider ratio
return analogRead(A3) * 3.3f / 1023.0f * 11.0f;
// in setup(), before driver.init()
float vbus = readSupplyVoltage();
// fall back to 12V if the voltage sensing pad is not soldered
driver.voltage_power_supply = vbus > 6 ? vbus : 12;
Use 5.0f instead of 3.3f on 5V boards such as the Arduino UNO. Most Arduino cores return 10-bit values (0-1023) by default; if you call analogReadResolution(12), use 4095.
You can also read the voltage in loop(), for example to stop the motor when a battery runs low. Don’t read it on every loop, as analogRead() is slow. With InlineCurrentSense, analogRead() is fine. If you use LowsideCurrentSense (see the tip in step 4), analogRead() can interfere with the current measurements on some MCUs, see regular ADC reads during FOC.
Add the Commander interface with the full motor commands, and enable monitoring. Then you can change the target, the control mode and the PID gains at runtime, and the code works directly with the SimpleFOC web controller:
// in setup()
motor.monitor_start_char = 'M'; // must match the commander ID for the web controller
motor.monitor_end_char = 'M';
motor.monitor_downsample = 0; // disabled at start, enable from the web controller
// in loop()
motor.monitor();
Open the web controller, connect to the serial port at 115200 baud, and you can plot the angle, velocity and currents, and tune the motor with sliders. In the serial monitor, the commands start with M: M0.5 sets the target, MC1 switches to velocity control, MVP0.2 sets the velocity P gain, etc.
On the Arduino UNO, the full motor commands don’t fit in the flash. Use a simple target command instead, as in step 1:
command.scalar(&motor.target, cmd).
Full code
Here is everything put together. Choose your sensor:
STM32 Nucleo, ESP32 and other larger boards
FOC current control, voltage sensing, and the full Commander interface for the web controller. Set VDD to 3.3V.
// BLDC motor: pole pairs
// driver: PWM A, B, C, enable
// current sense: 5mΩ shunts, INA240 gain 50
// commander interface, compatible with the web controller
// sensor
// driver
// current sensing
// FOC current torque control
// monitoring for the web controller
Serial.println(F("Motor ready. Set the target with M<value>, e.g. M0.5"));
motor.monitor();
Send M0.5 to apply 0.5A, or connect with the web controller.
Arduino UNO
Voltage control and a simple target command, to fit in the flash. Set VDD to 5V.
return analogRead(A3) * 5.0f / 1023.0f * 11.0f;
// commander: only the target, the full motor commands do not fit in the UNO flash
// sensor
// driver
// voltage torque control (no current sensing on the UNO)
command.add('T', doTarget, "target");
Serial.println(F("Motor ready. Set the target with T<value>, e.g. T2"));
Send T2 to apply 2V. To switch to velocity or angle control, change motor.controller, see motion control.
All these examples are compiled for an Arduino UNO and an STM32 Nucleo-F411RE.
The Shield can also drive a 2-phase stepper motor, such as a NEMA 17, using the HybridStepperMotor class. A stepper has two coils, A and B, and the Shield has three outputs: each coil is connected between its own output and a third, common output, and the library drives the common output so that both coils get the full voltage range.
Wiring
Connect the stepper wires in the order A+, A-/B-, B+: one wire of each coil to the outer terminals, and the other wire of both coils together to the middle terminal:
| Shield motor terminal | Stepper wires |
A | A+ |
B | A- and B- together (common) |
C | B+ |
The library uses the third PWM pin of the driver as the common phase. With the common on terminal B, give the driver the PWM pins in the order A, C, B:
// PWM A, PWM C, PWM B (common), enable
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 5, 10, 8);
It doesn’t matter which wire of a coil is + or -, as long as both coils share the common terminal. If you’re not sure which wires belong to the same coil, measure with a multimeter: the two wires of a coil have a few Ω between them, and wires of different coils are not connected.
Code changes
Only the motor class, the order of the driver pins and the current sense pins change, everything else in this guide stays the same:
// pole pairs = steps per revolution / 4 (50 for a 200-step NEMA 17)
HybridStepperMotor motor = HybridStepperMotor(50);
// current sensing on coil A (A2) and coil B (A0), the common is not measured
InlineCurrentSense current_sense = InlineCurrentSense(0.005f, 50.0f, A2, A0);
Steppers have a much lower phase resistance than gimbal motors, typically 1-3Ω, so always limit the current. Set motor.current_limit to the rated current of the stepper with current sensing, or motor.voltage_limit to about the rated current times the phase resistance without it. The current sensing and initFOC() alignment work the same as for a BLDC motor.
Full code: stepper motor
FOC current control with the full Commander interface, for STM32 Nucleo, ESP32 and other larger boards:
// stepper motor: pole pairs = steps per revolution / 4 (50 for a 200-step NEMA 17)
// driver: PWM A, PWM C, PWM B, enable - terminal B is the common wire of the stepper
// current sense: 5mΩ shunts, INA240 gain 50, measuring coil A (A2) and coil B (A0)
// sensor
// driver
// current sensing
motor.current_limit = 1; // Amps, set to the rated current of your stepper
motor.monitor();
For a complete stepper project with the Shield, see the stepper control example.
Going further
Two motors
Two stacked Shields run two motors from one microcontroller. Configure the solder pads of each board with different pins, see the stacking pinouts, and create two of everything:
BLDCMotor motor1 = BLDCMotor(7);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(6, 10, 5, 8);
InlineCurrentSense current_sense1 = InlineCurrentSense(0.005f, 50.0f, A2, _NC, A0);
BLDCMotor motor2 = BLDCMotor(7);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(13, 9, 3, 7);
InlineCurrentSense current_sense2 = InlineCurrentSense(0.005f, 50.0f, A3, _NC, A1);
motor1.loopFOC();
motor2.loopFOC();
motor1.move();
motor2.move();
Two motors with current control need a fast microcontroller: both FOC loops share the processor, so each runs at half the rate. Running them from a timer keeps the rate fixed, see the real-time loop guide.
More to explore
- Sensorless control: run the motor without a position sensor, using the current sensing
- Settings storage: save the sensor calibration and tuned gains, and skip the alignment on startup
- Motion control: velocity and angle control, and how to tune them
- Getting started guide: the library’s step-by-step guide, with more detail on each step
- Example projects built with the SimpleFOCShield
