Velocity control example
using Drotek’s L6234 driver
Drotek’s L6234 breakout board is a very minimalistic 3-phase BLDC motor driver and is very suitable for jump-starting your FOC experience. Here we the velocity control example project using the SimpleFOClibrary and this hardware:
For a bit more in depth explanation of Arduino UNO and L6234 connection please check the connection examples.
  • Encoder channels A and B are connected to the Arduino’s external interrupt pins 2 and 3.
  • Connected to the arduino pins 9,10 and 11 (you can use also pins 5 and 6).
  • Additionally you can connect the enable pin to the any digital pin of the arduino the picture shows pin 8 but this is optional. You can connect the driver enable directly to 5v.
  • Make sure you connect the common ground of the power supply and your Arduino
  • Motor phases a, b and c are connected directly to the driver outputs
Encoder code
// define Encoder
Motor code
First we need to define the BLDCMotor class with the number of pole pairs (14)
// define BLDC motor
BLDCMotor motor = BLDCMotor(14);
Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
Now we configure the PI controller parameters
// default P=0.5 I = 10
motor.voltage_limit = 6;
For more information about the velocity control loop parameters please check the doc.
And finally we connect the encoder and the driver to the motor, do the hardware init and init of the Field Oriented Control.
// iterative FOC function
// iterative function setting and calculating the velocity loop
motor.move(target_velocity);
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change velocity target value in real time.
BLDCMotor motor = BLDCMotor( 14 );
// define Encoder
// velocity set point variable
float target_velocity = 0;
void onTarget(char* cmd){ command.scalar(&target_velocity, cmd); }
  // default 12V
  Serial.println("Set the target velocity using serial terminal:");
  // iterative foc function
