Motion control implementation v2.4+
BLDC motors Stepper motors
Motion control is the outer control loop in the SimpleFOClibrary, executed within move(). It converts user commands (position, velocity, or torque targets) into a current setpoint (current_sp) that is passed to the torque control layer in loopFOC().
The library implements 7 motion control strategies:
enum MotionControlType : uint8_t {
  torque            = 0x00,     // Direct torque/current control
  velocity          = 0x01,     // Velocity motion control
  angle             = 0x02,     // Position control (cascade)
  velocity_openloop = 0x03,     // Open-loop velocity
  angle_openloop    = 0x04,     // Open-loop position
  angle_nocascade   = 0x05,     // Position control (direct)
  custom            = 0x06      // User-defined control
Selection:
motor.controller = MotionControlType::velocity;  // Can be changed in real-time
The move() function
Motion control is executed in the move() function, which should be called iteratively in the main loop. The function accepts an optional target parameter; if omitted, it uses motor.target.
  motor.loopFOC();        // Fast: torque control
  motor.move();           // Slower: motion control
  // or
  motor.move(new_target); // Override motor.target
The real-time motion control is executed inside the move() function. This function executes one of the control loops based on the controller variable. The parameter new_target is the target value to be set for the control loop. The new_target value is optional; if not set, the motion control will use the motor.target variable.
Here is a simplified view of the implementation:
// Iterative function running outer loop of the FOC algorithm
// Behavior of this function is determined by the motor.controller variable
// - needs to be called iteratively, it is an asynchronous function
// - if target is not set it uses motor.target value
void FOCMotor::move(float new_target) {
  // set internal target variable
  if(_isset(new_target)) target = new_target;
  // downsampling (optional)
  if(motion_cnt++ < motion_downsample) return;
  motion_cnt = 0;
  // read sensor values (except for open loop modes)
  if(controller != MotionControlType::angle_openloop &&
     controller != MotionControlType::velocity_openloop) {
    shaft_angle = shaftAngle();
    shaft_velocity = shaftVelocity();
  // if disabled or not ready, do nothing
  if(!enabled || motor_status != FOCMotorStatus::motor_ready) return;
  // choose control loop
  switch (controller) {
    case MotionControlType::torque:
      current_sp = target;
      break;
    case MotionControlType::angle_nocascade:
      // angle set point
      shaft_angle_sp = target;
      // calculate the torque command directly from position error
      current_sp = P_angle(shaft_angle_sp - LPF_angle(shaft_angle));
      break;
    case MotionControlType::angle:
      // angle set point
      // calculate velocity set point
      shaft_velocity_sp = feed_forward_velocity + P_angle(shaft_angle_sp - LPF_angle(shaft_angle));
      shaft_velocity_sp = _constrain(shaft_velocity_sp, -velocity_limit, velocity_limit);
      current_sp = PID_velocity(shaft_velocity_sp - shaft_velocity);
      break;
    case MotionControlType::velocity:
      // velocity set point
      shaft_velocity_sp = target;
      break;
    case MotionControlType::velocity_openloop:
      current_sp = velocityOpenloop(shaft_velocity_sp);
      break;
    case MotionControlType::angle_openloop:
      current_sp = angleOpenloop(shaft_angle_sp);
      break;
    case MotionControlType::custom:
      // custom control - user provides the callback function
      if(customMotionControlCallback)
        current_sp = customMotionControlCallback(this, target);
      break;
The move() function is typically called at the same frequency as loopFOC(), but it can be downsampled using the motion_downsample variable to reduce computational load. This can allow for more complex motion control algorithms that do not need to run at the full speed of the torque control loop.
\[f_{MC} = \frac{f_{TC}}{\texttt{motion_downsample} }\]
Torque Mode
Type: MotionControlType::torque
Direct torque/current control - the target value is passed directly as the current setpoint to the torque controller.
  break;
The actual torque control strategy (voltage, DC current, FOC current, estimated current) is determined by motor.torque_controller.
Detailed implementation
For detailed information about torque control modes, see the torque control implementation page.
Torque control API documentation
Velocity Control
Type: MotionControlType::velocity
Closed-loop velocity control using a PID controller to calculate the current setpoint from velocity error.
Control Flow
  break;
Velocity Controller
The PID_velocity controller is a PIDController object. Also note the low-pass filtering of the velocity measurement before calculating the error.
motor.PID_velocity.I = 20.0;
motor.PID_velocity.D = 0.0;
motor.LPF_velocity.Tf = 0.01;  // 10ms low-pass filter time constant
Velocity control API documentation PID controller implementation
Additional Features
Velocity low-pass filtering:
Low-pass filter implementation
Position Control (Cascade Mode)
Type: MotionControlType::angle
Cascaded position control: P controller generates velocity setpoint, then velocity PID calculates current setpoint.
Control Flow
  // P controller calculates velocity setpoint
  // Constrain velocity
  // Velocity PID calculates current setpoint
  break;
Position Controller
The P_angle controller is a PIDController object (though typically only P gain is used):
motor.P_angle.P = 20.0;      // Proportional gain
motor.P_angle.I = 0.0;       // Usually zero
motor.P_angle.D = 0.0;       // Usually zero
Angle control API documentation PID controller implementation
Additional Features
Angle low-pass filtering:
motor.LPF_angle.Tf = 0.0;  // Usually disabled (0)
Feed-forward velocity:
motor.feed_forward_velocity = 0.5;  // [rad/s]
Velocity limiting:
motor.velocity_limit = 10.0;  // [rad/s]
Position Control (Non-Cascade Mode)
Type: MotionControlType::angle_nocascade
Direct position-to-torque control without velocity loop intermediary - P controller directly calculates current setpoint.
Control Flow
  break;
Position Controller
motor.P_angle.I = 0.0;       // Usually very low or zero
Non-cascade angle control API documentation PID controller implementation
Additional Features
Open-Loop Velocity Control
Type: MotionControlType::velocity_openloop
Open-loop velocity control without sensor feedback - generates rotating field at target velocity.
Control Flow
  break;
The velocityOpenloop() function integrates velocity to calculate angle:
float FOCMotor::velocityOpenloop(float target_velocity) {
  unsigned long now_us = _micros();
  float Ts = (now_us - open_loop_timestamp) * 1e-6f;
  if(Ts <= 0 || Ts > 0.5f) Ts = 1e-3f;
  shaft_angle = _normalizeAngle(shaft_angle + target_velocity * Ts);
  shaft_velocity = target_velocity;
  open_loop_timestamp = now_us;
  return current_sp;
Open-loop velocity control API documentation
Open-Loop Position Control
Type: MotionControlType::angle_openloop
Open-loop position control - sets electrical angle directly without sensor feedback.
Control Flow
  break;
The angleOpenloop() function sets the angle and applies velocity ramping:
float FOCMotor::angleOpenloop(float target_angle) {
  // Calculate angle difference
  float angle_diff = _normalizeAngle(target_angle - shaft_angle);
  // Apply velocity limit
  if(abs(angle_diff) > velocity_limit * Ts) {
    angle_diff = _sign(angle_diff) * velocity_limit * Ts;
  shaft_angle = _normalizeAngle(shaft_angle + angle_diff);
  return current_sp;
Open-loop position control API documentation
Custom Control
Type: MotionControlType::custom
User-defined control algorithm via callback function.
Control Flow
  break;
Usage
Set the callback function pointer:
// Define custom control function
float myCustomControl(FOCMotor* motor, float target) {
  // Your control algorithm here
  // Access motor state: motor->shaft_velocity, motor->shaft_angle, etc.
  // Return current setpoint
  return calculated_current_sp;
// Register callback
motor.customMotionControlCallback = myCustomControl;
motor.controller = MotionControlType::custom;
Custom control API documentation
