Units in the library
All the motor/driver/sensor parameters and control variables are defined in the following units:
Physical value Description Unit Comment
Position/angle Radians RAD Motor and sensor position in radians
Velocity Radians per second RAD/s Motor and sensor velocity in radians per second
Torque/Current Amperes A Motor torque or current
Voltage Volts V Motor/Driver voltage
Phase resistance Ohms Ω Motor phase resistance
Phase inductance Henries H Motor phase inductance
KV rating Rotations per minute per volt rpm/V Motor velocity constant
PWM frequency Hertz Hz Motor/driver PWM frequency
PMW duty cycle No unit - All duty cycles have the range: 0 - 1.0
Position/angle units
The motor and sensor position is defined in radians. One full rotation of the motor is equal to \(2\pi\) (6.14) radians is equal to 360 degrees.
Some important variables in radians (RAD)
  • motor.shaft_angle - the current motor position in radians
  • motor.electrical_angle - the current motor electrical position in radians
  • motor.target - the target motor position in radians ( in closed-loop and open-loop angle control)
  • sensor.getAngle() - the current sensor position in radians ( in closed-loop control)
Converting the angle to degrees
In order to convert the angle from radians to degrees, you can use the following formula:
\[a_{deg} = a_{rad} \cdot \frac{360}{2\pi}\]
Setting the target angle in degrees
For example, if you wish to set the target angle in degrees:
motor.target = my_target_in_degrees * _2PI/360;
Or for example if you’re using commander interface to set the target angle in degrees:
void onTarget(char* cmd){
    // get the target angle in degrees
    float target_angle_deg = atof(cmd);
    // set the target angle in radians
    motor.target = target_angle_deg * _2PI/360;
    // add the command to the commander
    commander.add('A', onTarget, "angle in degrees");
Reading the sensor angle in degrees
If you wish to read motor position in degrees, you can easily convert it using
float angle_deg = motor.shaft_angle * 360/_2PI;
The same can be done for the outputs of the Sensor class:
float angle_deg = sensor.getAngle() * 360/_2PI;
Converting the angle to rotations (turns)
To convert the angle from radians to turns (rotations) you can use the following formula:
\[a_{rot} = a_{rad} \cdot \frac{1}{2\pi}\]
Setting the target angle in turns
For example, if you wish to set the target angle in turns:
motor.target = my_target_in_turns / _2PI;
Or for example if you’re using commander interface to set the target angle in turns:
    // get the target angle in turns
    float target_angle_turns = atof(cmd);
    motor.target = target_angle_turns / _2PI;
    commander.add('A', onTarget, "angle in turns");
Reading the sensor angle in turns
If you wish to read motor position in turns, you can easily convert it using
float angle_turns = motor.shaft_angle / _2PI;
float angle_turns = sensor.getAngle() / _2PI;
Velocity units
All the parameters/variables related to the velocity, both for the motor and sensor, are defined in radians per second. One full rotation of the motor is equal to \(2\pi\) (6.14) radians is equal to 360 degrees. Some other standard units for the velocity are RPM (revolutions per minute) and 1/s (turns per second).
Some important variables in radians per second (RAD/s)
  • motor.shaft_velocity - the current motor velocity in radians per second
  • motor.velocity_limit - the velocity limit in radians per second
  • motor.shaft_velocity - the current motor velocity in radians per second ( in closed-loop control)
  • motor.target - the target motor velocity in radians per second ( in closed-loop and open-loop velocity control)
  • sensor.getVelocity() - the current sensor velocity in radians per second ( in closed-loop control)
Converting the velocity to RPM
In order to convert the velocity from radians per second to RPM, you can use the following formula:
\[v_{RPM} = v_{RAD/s} \cdot \frac{60}{2\pi}\]
RULE OF THUMB
The motor velocity in RPM is approximately 10 times the motor velocity in radians per second RAD/s, as \(\frac{60}{2\pi}\approx 10\)
So the conversion can be approximated as:
\[v_{RPM} = 10 \cdot v_{RAD/s}\]
Setting the target velocity in RPM
For example, if you wish to set the target velocity in RPM:
motor.target = my_target_in_RPM * _2PI/60;
Or for example if you’re using commander interface to set the target velocity in RPM:
    // get the target velocity in RPM
    float target_velocity_RPM = atof(cmd);
    // set the target velocity in radians per second
    motor.target = target_velocity_RPM * _2PI/60;
    commander.add('V', onTarget, "velocity in RPM");
Reading the sensor velocity in RPM
If you wish to read motor velocity in RPM, you can easily convert it using
float velocity_RPM = motor.shaft_velocity * 60/_2PI;
float velocity_RPM = sensor.getVelocity() * 60/_2PI;
Converting the velocity to turns per second
To convert the velocity from radians per second to turns per second, you can use the following formula:
\[v_{tps} = v_{rad/s} \cdot \frac{1}{2\pi}\]
Setting the target velocity in turns per second
For example, if you wish to set the target velocity in turns per second:
motor.target = my_target_in_tps / _2PI;
Or for example if you’re using commander interface to set the target velocity in turns per second:
    // get the target velocity in turns per second
    float target_velocity_tps = atof(cmd);
    motor.target = target_velocity_tps / _2PI;
    commander.add('V', onTarget, "velocity in turns per second");
Reading the sensor velocity in turns per second
If you wish to read motor velocity in turns per second, you can easily convert it using
float velocity_tps = motor.shaft_velocity / _2PI;
float velocity_tps = sensor.getVelocity() / _2PI;
Torque/Current units
The motor torque or current is defined in Amperes. The torque is directly proportional to the current flowing through the motor windings. The torque constant \(K_t\) is a parameter that describes the relationship between the motor torque and the current.
Some important variables in Amperes [A]
  • motor.current_limit - the current motor limit in Amperes
  • motor.target - the target motor current in Amperes ( in closed-loop torque control or in voltage control with current estimation)
  • motor.currents.q - the current motor currents in Amperes
  • current_sense.getFOCCurrents() - the current motor currents in Amperes
  • current_sense.getDCCurrent() - the current measured current magnitude in Amperes
  • current_sense.getPhaseCurrents() - the current motor phase currents in Amperes
  • PhaseCurrent_s - the structure that holds the motor phase currents in Amperes
  • DQCurrent_s - the structure that holds the D and Q motor currents in Amperes
  • ABCurrent_s - the structure that holds the Alpha and Beta motor currents in Amperes
Converting the current to torque
The motor torque is directly proportional to the current through the torque constant \(K_t\). The torque constant is defined in the motor datasheet and often can be approximated to be the same as the electrical (BEMF) constant \(K_t \approx K_e\).
\[\tau = K_t \cdot I\]
Setting the target torque in Nm
For example, if you wish to set the target torque in Nm:
float Kt = ....; // datasheet value
motor.target = my_target_in_Nm / Kt; // Nm / (Nm/A) = Amps
Or for example if you’re using commander interface to set the target torque in Nm:
    // get the target torque in Nm
    float target_torque_Nm = atof(cmd);
    // set the target current in Amperes
    motor.target = target_torque_Nm / Kt;
    commander.add('T', onTarget, "torque in Nm");
Reading the sensor current in Nm
If you wish to read motor current in Nm, you can easily convert it using
float current_Nm = motor.currents.q * Kt;
Or directly from the current sensor:
DQCurrent_s c = current_sense.getFOCCurrents();
float current_Nm = c.q * Kt; // torque in Nm
