Current sensing
Arduino SimpleFOClibrary has as a goal to support FOC implementation with (at least) three most standard types of current sensing:
- In-line current sensing
- Low-side current sensing
- High-side current sensing - Not supported yet
- Generic current sensing - for custom current sensing implementations
up to this moment ( check the releases ), Arduino SimpleFOClibrary supports in-line and low-side current sensing on a wide range of platforms. The generic current sensing method allows you to use any custom current sensing method by providing callbacks to read the currents, without needing to create a new class.
Each one of the current sensing classes will implement all the necessary functionalities for simple and robust implementation of FOC algorithm:
- Hardware config
- ADC resolution and frequency
- Automatic zero offset finding
- Driver synchronisation
- ADC acquisition events triggering
- Adaptive alignment with driver phases
- Reading the phase currents
- Calculation of the current vector magnitude
- Calculation of the FOC D and Q currents
Each of the implemented classes can be used as stand-alone classes and they can be used to read current values on BLDC or Stepper driver outputs out of scope of the Arduino SimpleFOClibrary, see example codes in utils > current_sense_test. In order for FOC algorithm to work the current sense classes are linked to a BLDCMotor, StepperMotor or HybridStepperMotor class which uses the driver to read the FOC currents.
What current sensing enables
Adding current sensing to your setup unlocks several features of the library:
- FOC current control: precise control of the motor torque, with real current limiting
- Motor characterisation: measure the phase resistance and inductance automatically
- Current loop auto-tuning: tune the current PI controllers from the measured motor parameters
- Sensorless control: run FOC without a position sensor, estimating the rotor angle from the phase currents
π― Our implementation goals
The current sense code will be written in a way to support as many different drivers out there as possible and in a way to be fully interchangeable. Due to the very hardware specific implementations of the ADC acquisition for different MCU architectures and due to very different driver/adc synchronisation requirements for different current sensing approaches this task is probably one of the most complex challenges for the SimpleFOClibrary so far. Therefore the work will be done in iterations and each release will better and better support. Please make sure to follow out github and check the releases .
Also make sure to follow our community forum, a lot of discussions is being held about current sensing and its applications!
| MCU | In-line | Low-side | High-side |
| Arduino (8-bit) | βοΈ | β | β |
| Arduino DUE | βοΈ | β | β |
| stm32 (in general) | βοΈ | β | β |
| stm32f1 family | βοΈ | βοΈ | β |
| stm32f4 family | βοΈ | βοΈ | β |
| stm32g4 family | βοΈ | βοΈ | β |
| stm32l4 family | βοΈ | βοΈ | β |
| stm32f7 family | βοΈ | βοΈ | β |
| stm32h7 family | βοΈ | βοΈ | β |
| stm32 B_G431B_ESC1 | β | βοΈ (one motor) | β |
| esp32/esp32s3 | βοΈ | βοΈ | β |
| esp32s2/esp32c3 | βοΈ | β | β |
| esp8266 | β | β | β |
| samd21 | βοΈ | βοΈ (one motor) | β |
| samd51 | βοΈ | β | β |
| teensy3 | βοΈ | β | β |
| teensy4 | βοΈ | βοΈ(one motor) | β |
| Raspberry Pi Pico | βοΈ | β | β |
| Portenta H7 | βοΈ | β | β |
| nRF52 | βοΈ | β | β |
| Renesas (UNO R4) | β | β | β |
| Arduino Nano Matter(π’NEW) | βοΈ | βοΈ (one motor) | βοΈ (not tested) |
Note: current sensing on Renesas MCUs will be added in a future release.
Digging deeper
For more theoretical explanations and source code implementations of the current sensing and its integration into the FOC and motion check out the digging deeper section.
Learn about current sensing theory and implementation
