Stepper motor control example
using L298N and Stm32 Nucleo-64
For this stepper motor control example we are going to be using this hardware:
Download the STL file as well as STEP and solidworks project of the amt103 mount on the nema17 used in the images and the Youtube video here.
Here is an example of the connection scheme using the L298N and Nucleo-64:
L298N
  • Channels ENA and ENB are connected to pins 7 and 8
  • Channels IN1, IN2, IN3 and IN4 are connected to the pins 5, 6, 9, 10
  • Common ground is connected in between nucleo and L298N
  • 12V power-supply is connected directly to the driver
  • Channels A and B are connected to the pins A0 qnd A1
  • Index channel is not used in this example but you can easily modify this example to support it
  • Motor phases A1, A2, B1and B2 are connected directly the motor connectors of the L298N chip.
Full Arduino code
// Stepper motor instance
StepperMotor motor = StepperMotor(50);
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10,  8, 7);
Encoder encoder = Encoder(A1, A2, 2048);
  // choose FOC modulation
  motor.PID_velocity.D = 0;
  motor.voltage_limit = 12;
  // angle loop controller
  // angle loop velocity limit
  motor.velocity_limit = 50;
  motor.target = 2;
  // define the motor id
  // if target not set in parameter uses motor.target variable
