β˜… Loading...
FOC Current Control (Guide)
FOC current control provides precise torque control using current sensing. This is the most accurate current control method and enables advanced features like current limiting, automatic compensation of Back-EMF, and cross-coupling compensation.
Read more about FOC current control
What you need
Before enabling FOC current control, you need:
  1. Current sensing hardware - Inline or lowside current sensors - REQUIRED
  2. Working motor setup - already tested and working
If you don’t have current sensors, see the - Estimated Current Control Guide
Guide steps
This guide follows a 2-step process:
  1. Setup and verify current sensing - Configure hardware and validate current measurements
    Start with step 1: Setup and verify current sensing
  2. Enable full current control - Switch from voltage to current-based torque control
    Continue to step 2: Enable full current control
Table of contents
