Implementing a custom current sense
GenericCurrentSense is a helper class that makes it easy to integrate a custom current-sensing setup into the SimpleFOClibrary. You provide callbacks to read phase currents (and optionally initialize your hardware), and the library handles offsets, filtering, and integration with FOC control.
For advanced users, you can also implement your own class by inheriting CurrentSense, but GenericCurrentSense is usually faster to get working.
See library source code for more details (Advanced)
Step 1. Implement the current-reading callback
Provide a function that returns phase currents in amps. If you only measure two phases, set the third one to 0.
PhaseCurrent_s readCurrentSense(){
        PhaseCurrent_s c;
        // Read your ADCs and convert to amps
        c.a = ...; // phase A current [A]
        c.b = ...; // phase B current [A]
        c.c = ...; // phase C current [A] (set to 0 if not measured)
        return c;
You can also provide an optional initialization callback:
void initCurrentSense(){
	// Configure ADCs, GPIOs, or any hardware setup
Step 2. Instantiate GenericCurrentSense
// GenericCurrentSense constructor
//  - readCallback pointer to the function reading phase currents
//  - initCallback pointer to the optional init function
GenericCurrentSense current_sense = GenericCurrentSense(readCurrentSense, initCurrentSense);
If you prefer, you can also assign callbacks after construction:
GenericCurrentSense current_sense;
current_sense.readCallback = readCurrentSense;
current_sense.initCallback = initCurrentSense;
Step 3. Use as a standalone current sensor
Once initialized, you can read phase currents and DC current directly:
Serial.print(currents.a);
Serial.print(currents.b);
Serial.print(currents.c);
Serial.println(current_magnitude);
Offset calibration
GenericCurrentSense::init() automatically runs a zero-offset calibration by sampling your callback multiple times. Make sure the motor is not driven during initialization.
Step 4. Use with FOC control
To use current sensing for torque control (dc_current or foc_current), link it to the motor and driver:
// Driver and motor
	// Driver init
	// Current sense init and link
	// Select torque control mode
	// or TorqueControlType::dc_current
Tips and troubleshooting
  • Units matter: your callback must return currents in amps.
  • Only two shunts? Set one of the phases to 0 and the library will estimate it.
  • Phase inversion: if a phase appears inverted, you can flip it:
      current_sense.gain_a *= -1; // or gain_b / gain_c
  • Alignment: initFOC() will not run the alignment for this sensor type, so make sure your callback returns correct angles from the start.
Example: Generic current sensing test
	PhaseCurrent_s c;
	c.a = analogRead(A0);
	c.b = analogRead(A1);
	c.c = analogRead(A2);
	return c;
	pinMode(A0, INPUT);
	pinMode(A1, INPUT);
	pinMode(A2, INPUT);
	Serial.println("Current sense ready");
