Current Sense Testing and Validation
⏱️ ~20-40 minutes
This guide shows how to setup hardware current sensing and validate that d/q current measurements are working correctly in closed-loop FOC.
Read more about current sensing in SimpleFOC
Prerequisites
Before starting, make sure you already have:
- Working sensor and driver setup - Sensor setup guide and Driver setup guide
- Closed-loop FOC working in voltage torque mode - Closed-loop voltage control guide
Current sensing hardware
You also need current sensing hardware:
- Inline current sensors (recommended for beginners) - measures phase currents directly
- Lowside current sensors (requires precise timing) - measures currents through low-side shunts
Read more about choosing current sensing hardware
Step 1: Configure current sensing
Add current sensing to your working closed-loop FOC code.
Select Your Motor + Driver + Sensor + Current Sense Combo
Now validate that d/q currents are visible and behaving as expected in closed-loop FOC.
Sketch Template BLDC + 3PWM + Encoder + Lowside CS Stepper + 2PWM + Encoder + Inline CS
Template with TODO entries:
// TODO: motor instance
// TODO: driver instance
// TODO: sensor instance
// TODO: current sense instance
// init the sensor
// init the driver
driver.voltage_power_supply = TODO; // set your power supply voltage
if(!driver.init()){
Serial.println("Driver init failed!");
return;
// IMPORTANT: link driver to current sense
// init current sense
if(!current_sense.init()){
Serial.println("Current sense init failed!");
return;
// link current sense to motor
motor.voltage_sensor_align = 3;
// enable current monitoring
motor.monitor_downsample = 100;
motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D;
if(!motor.init()){
Serial.println("Motor init failed!");
return;
if(!motor.initFOC()){
Serial.println("FOC init failed!");
return;
motor.target = 0;
command.add('M', doMotor, "Motor");
Serial.println(F("Motor ready - Current sensing active."));
motor.monitor();
Copy this code to your application and fill in the TODO entries with your hardware parameters. Then upload and open the serial monitor to validate that current sensing is working correctly.
Key Configuration: Current Sense Parameters
There are two current sense strategies implemented in SimpleFOC:
- Inline Current Sense (
InlineCurrentSense) - For inline current sensing techniques - Lowside Current Sense (
LowsideCurrentSense) - For lowside current sensing techniques (requires precise ADC & PWM timing)
Both InlineCurrentSense and LowsideCurrentSense require accurate configuration of the current sense parameters to work correctly. Either shunt resistance and amplifier gain, or the overall current sense ratio can be used.
Inline Current Sense Parameters Lowside Current Sense Parameters
InlineCurrentSense(shunt_resistance, amplifier_gain, pin_A, pin_B, pin_C);
// or
InlineCurrentSense(current_sense_ratio_mV_per_A, pin_A, pin_B, pin_C);
See current sensing documentation for detailed parameter selection based on your hardware.
Common Configurations
| Sensor Type | Shunt Resistance [Ω] | Gain [V/V] | Overall Gain [mV/V] | Range @ 5V | Example |
| Allegro ACS712 (30A) | - | - | 66 | ±30A | InlineCurrentSense(66.0f, A0, A1) |
| Custom Shunt (0.01Ω) + INA240A2 | 0.01 Ω | 50 | 500 | ±5A | InlineCurrentSense(0.01f, 50.0f, A0, A2) |
| Custom Shunt (0.005Ω) + INA240A1 | 0.005 Ω | 20 | 100 | ±25A | LowsideCurrentSense(0.005f, 20.0f, A0, A2) |
Consult Current Sensing docs for your specific configuration.
Critical: ADC Pin Selection
Current sense requires ADC pins (analog input). Not all pins have ADC:
✅ Use ADC pins like: A0, A1, A2, A3, A4, A5 (Arduino like boards)
❌ Avoid digital-only pins: D0, D1, etc.
See Choosing ADC Pins guide for your microcontroller.
Step 2: Validate d/q current measurements
Once current sensing is configured, test that d/q currents are measured correctly in closed-loop operation.
What to expect
- Serial terminal shows motor current q and d current values in milliamps (
IqandId)TIP: Visualize currents in Arduino Serial Plotter for easier analysis
- Current values update smoothly with motor torque changes
- You can see
Iq(torque current) change as you adjust target Id(field current) should stay near zero at low speeds
Validation procedure
Test that current measurements respond correctly to motor commands:
- Static motor test:
- Set target voltage
M0 - Hold motor firmly in place
- Set
M1(1 Volts) - Current
Iqshould be proportional to the voltage command (2x voltage should give ~2x current) - Current
Idshould be close to 0
- Rotating motor test:
- Release motor, set
M2 - Motor spins steadily
- Current
Iqshould drop as back-EMF increases with speed - Current
Idmay rise slightly at higher speeds but should remain much lower thanIq- It drops to zero if motor stalled by hand
Troubleshooting
Current sense init failed?
- Check pins are actual ADC pins
- Verify pins are not used for PWM
- See Choosing ADC Pins guide
Motor movement is jittery or unstable?
- This probably means that there is too much serial output or the current values are too noisy
- Try increasing
motor.monitor_downsampleto 500 or 1000 to reduce serial output frequency - You can also use the Commander interface without re-uploading (ex $MMD500$ to set monitor downsampling to 500)
Current values are noisy but respond correctly?
- Check motor connections and wiring
- If current noisy a bit, but responds to commands correctly, try increasing current filtering:
motor.LPF_current_q.Tf = 0.001; // increase low-pass filter for Iq - default is 0.0005s motor.LPF_current_d.Tf = 0.001; // increase low-pass filter for Id - default is 0.0005sor in commander:
MQF0.001 # set Iq filter time constant to 1ms MDF0.001 # set Id filter time constant to 1ms
Current reads wrong values ?
- If current values cannot correspond the motor parameters (too high or low)
BEWARE: Current is shown in milliamps (mA), not amps (A)
- Check current sense parameters (shunt resistance, gain) are correct
- Verify amplifier gain (check sensor datasheet)
Current doesn’t change with motor commands?
- Check that you’re measuring on the correct pins!
Currents are too noisy and do not respond to target changes?
- Make sure you’re not using Inline current sensing with a driver that requires Lowside current sensing (e.g., DRV8302)
D and q currents are not static but sinusoidally changing?
- This usually means the current sense is not well aligned with the motor - did the
initFOC()function complete successfully? - Try raising
motor.voltage_sensor_alignparameter (e.g., 2, 3, 4, etc.) and re-runinitFOC()until currents stabilize - Verify your pins, gains and shunt values are correct and skip the current sense align if you’re sure in your parameters:
current_sense.skip_align = true; // before initFOC()
Next steps
Once you’ve validated that current sensing works and d/q currents are visible:
Start the step 2: Full FOC Current Control
