Motor + Driver Test (Open-Loop)
⏱️ ~15 minutes
Test your motor and driver together using open-loop control. This step determines your motor’s pole pair count and validates that the driver can control your specific motor.
⚠️ Important Safety Notice
  • Actual current will flow through your motor and electronics
  • Motor may spin unexpectedly if parameters are wrong
  • Secure your motor to prevent injury
  • Set power supply current limit appropriately
  • Be ready to power off if something seems wrong
Select Your Motor + Driver Combination
Sketch Template
BLDC Motor + 3PWM Driver BLDC Motor + 6PWM Driver
Stepper Motor + 2PWM Driver Stepper Motor + 4PWM Driver Hybrid Stepper Motor + 3PWM Driver Hybrid Stepper Motor + 6PWM Driver
// TODO: instantiate your motor
// TODO: instantiate your driver
void doLimit(char* cmd) { command.scalar(&motor.voltage_limit, cmd); }
  // enable more verbose output for debugging
  driver.voltage_power_supply = TODO: //set your power supply voltage;
  // limit the maximal dc voltage the driver can set
  driver.voltage_limit = TODO: //set your voltage limit; Usually half of power supply voltage is a good starting point
  if(!driver.init()){
    Serial.println("Driver init failed!");
    return;
  // limiting motor movements
  // start very low for high resistance motors
  // current = voltage / resistance, so try to be well under 1Amp
  motor.voltage_limit = TODO: //set your voltage limit;   // [V]
  // open loop control config
  // init motor hardware
  if(!motor.init()){
    Serial.println("Motor init failed!");
    return;
  // set the target velocity [rad/s]
  motor.target = 6.28; // one rotation per second
  command.add('L', doLimit, "voltage limit");
  // loop FOC algorithm, should be called as
  // frequently as possible for best
  // performance (e.g. 1kHz+)
// BLDCMotor(pole pair number);
BLDCMotor motor = BLDCMotor(TODO);
// BLDCDriver3PWM(pwmA, pwmB, pwmC, Enable(optional));
BLDCDriver3PWM driver = BLDCDriver3PWM(TODO, TODO, TODO, TODO); // set your pins
  if(!driver.init()){
    return;
  motor.voltage_limit = TODO: //set your voltage limit in volts;   // [V]
  if(!motor.init()){
    return;
// BLDCDriver6PWM(pwmAh, pwmAl, pwmBh, pwmBl, pwmCh, pwmCl, (en optional))
BLDCDriver6PWM driver = BLDCDriver6PWM(TODO, TODO, TODO, TODO, TODO, TODO, TODO); // set your pins
  if(!driver.init()){
    return;
  if(!motor.init()){
    return;
// StepperMotor(pole pair number);
StepperMotor motor = StepperMotor(TODO);
// StepperDriver2PWM(pwm1, dir1, pwm2, dir2,(en1, en2 optional))
StepperDriver2PWM driver = StepperDriver2PWM(TODO, TODO, TODO, TODO); // set your pins
  if(!driver.init()){
    return;
  if(!motor.init()){
    return;
// StepperDriver4PWM(ph1A, ph1B, ph2A, ph2B, (en1, en2 optional))
StepperDriver4PWM driver = StepperDriver4PWM(TODO, TODO, TODO, TODO, TODO, TODO); // set your pins
  if(!driver.init()){
    return;
  if(!motor.init()){
    return;
HybridStepperMotor motor = HybridStepperMotor(TODO);
BLDCDriver3PWM driver = BLDCDriver3PWM(TODO, TODO TODO, TODO); // set your pins
  if(!driver.init()){
    return;
  if(!motor.init()){
    return;
// HybridStepperMotor(pole pair number);
  if(!driver.init()){
    return;
  if(!motor.init()){
    return;
Setup Steps
  1. Copy the code: Find your motor + driver combination above and copy the code into a new Arduino sketch
  2. Update parameters:
    • Implement the TODOs in the code:
    • Pin numbers (PWM pins, enable pin, direction pins)
    • Power supply voltage
    • Pole pair count - start with a guess from your motor datasheet
    • Voltage limit (see guidance below)
  3. Upload and open Serial Monitor (115200 baud)
Voltage Limit Guide
The motor.voltage_limit directly determines current: current = voltage / phase_resistance
For gimbal motors (high resistance ~10Ω)
  • Examples work well with motor.voltage_limit = 3-5V
  • These motors are low-power and safe
For higher power motors
  • Find phase resistance from datasheet or measure it
  • Set limit to keep current below 2A: motor.voltage_limit = 2 * phase_resistance
  • Better yet: set motor.phase_resistance in code, then use motor.current_limit instead
If you don’t know phase resistance
  • Start very conservatively: motor.voltage_limit = 0.5V
  • Slowly increase if motor doesn’t spin
Testing
✓ What to expect
  1. See Motor ready! in serial terminal (not Motor init failed!)
  2. Motor spins once you set a target velocity
  3. In serial terminal, type T6.28 to set target to one rotation/sec
    • Motor should spin at exactly 1 rotation per second
    • If it spins faster/slower, your pole pair count is wrong
Finding Correct Pole Pair Count
This is why this test is valuable! If your motor doesn’t spin at exactly one rotation per second when you command 6.28 rad/s:
  1. Motor spins too slowly? → Try a lower pole pair number
  2. Motor spins too fast? → Try a higher pole pair number
  3. Adjust and test until exactly 1 rotation = T6.28 command
Once you find the right pole pair number, note it for the next step!
Troubleshooting
Motor doesn’t spin?
  • Check initialization messages in serial terminal
  • Verify pole pair number is reasonable (usually 2-15)
  • Increase motor.voltage_limit gradually (start at 1V)
  • Check motor is mechanically free to spin
Motor spins but is noisy/unstable?
  • Check the motor connection to the driver - are all phases connected correctly?
  • Is driver entering fault state - maybe the current is too high? Try lowering motor.voltage_limit
  • Check that your power supply can provide enough current for the motor - is it limiting current and causing voltage drop?
Current too high?
  • Reduce motor.voltage_limit
  • Verify you’re using right motor type (BLDC vs Stepper)
  • Check phase resistance of your motor
Next Step
Once you’ve confirmed:
  • ✓ Motor spins smoothly
  • ✓ Correct pole pair count found (spins 1 rotation per second at 6.28 rad/s)
  • ✓ Current is reasonable
Proceed to:
Closed-Loop Control
