Custom Motion Control
New experimental feature (not recommended for beginners)
This feature is still in its early stages and we are not 100% happy with the API of the implementation. We are open to suggestions and contributions, so if you have any ideas on how to improve it, please let us know.
This section is for advanced users that want to implement their own custom motion control algorithms.
BLDC motors Stepper motors
As all the other standard motion control approaches, the custom motion control approach is be executed in the motion control loop (motor.move()). This loop will calculate the target torque (current or voltage) to be applied to the motor using the underlying torque/FOC control loop (motor.loopFOC()) in order to achieve the desired motion.
To use the custom motion control loop, you need to set the motor.controller variable to MotionControlType::custom.
// set FOC loop to be used
motor.controller = MotionControlType::custom;
You can find some examples in examples/motion_control/custom_motion_control/ folder.
This custom motion control requires the user to provide their own implementation of the motion control:
// custom motion control function
float custom_motion_control(FOCMotor& motor) {
  // your code here
  // ex. simple proportional position control
  float error = motor->target - motor->shaft_angle;
  float target_torque = 10*error;
  // return the target torque to be applied to the motor
  return target_torque;
And then link this callback function to the motor instance:
motor.linkCustomMotionControl(custom_motion_control);
Target and limits
The custom motion control uses the motor.target variable as the desired user defied target entry, and the user can choose to respect or ignore the velocity limits motor.velocity_limit. The torque limits are enforced by the underlying torque control loop, so they will be respected regardless if the user chooses to use them in their custom control or not. (If the user code returns a target torque that is higher than the limits set by the user, the library is going to limit it to the set limits before applying it to the motor).
The units of the target variable is completely user defined, so it can represent any physical quantity that the user wants to control.
For example, if the user wants to implement a torque control in Newton-meters (Nm), the user can set the motor.target variable to represent the target torque in Nm.
float Kt = 0.1; // torque constant in Nm/A
float customTorqueControl(FOCMotor& motor) {
  // convert the target from Nm to Amps using the torque constant
  float target_in_Amps = motor->target / Kt;
  return target_in_Amps;
  // link the custom control method to the motor
  motor.linkCustomMotionControl(customTorqueControl);
  // set the control loop type to be used
  // set the torque control type to be used
What can I do with the custom motion control?
  • Implement any motion control algorithm you want, for example:
    • Position control with custom trajectory generation
    • Velocity control with custom acceleration profiles
    • Advanced control algorithms like model predictive control, sliding mode control, etc.
  • Implement control schemes with multiple sensors,
    • using different sensors for position and velocity feedback,
    • using external sensors like IMUs
    • using secondary sensors after gearing etc.
Custom control code example
Here is one basic example implementing custom motion control with the voltage mode torque control. The custom motion control is a simple proportional position control, where the target torque is proportional to the error between the target angle and the current angle. The user can change the PID parameters in runtime using the commander interface. As well as the target angle or change the motion control strategy to the standard ones.
#include <Arduino.h>
BLDCDriver3PWM driver = BLDCDriver3PWM(D6, D10, D5, D8);
MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, D4);
// void doMotion(char* cmd){ command.motion(&motor, cmd); }
// custom PID controller instance for the custom control method
// P controller with gain of 1.0f, no integral or derivative gain
PIDController custom_PID = PIDController(1.0f, 0, 0);
// custom motion control method
float positionPControl(FOCMotor* motor){
  // simple proportional position control
  // set the PID output limit to the motor voltage limit
  custom_PID.limit = motor->voltage_limit;
  return custom_PID(error); // return current command based on the error
// optional add the PID to command to be able to tune it in runtime
void doPID(char* cmd){ command.pid(&custom_PID, cmd); }
  // enable more verbose output for debugging
  // initialize sensor hardware
  driver.voltage_power_supply = 20;
  // set the custom control method
  motor.linkCustomMotionControl(positionPControl);
  // set the torque control type to voltage control
  motor.monitor_downsample = 0; // disable intially
  motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE; // monitor target velocity and angle
  //command.add('T', doMotion, "motion control"); // a bit less resource intensive
  command.add('C', doPID, "custom PID");
  // // motor monitoring
  motor.monitor();
// Stepper motor & driver instance
HybridStepperMotor motor = HybridStepperMotor(50);
  motor.monitor();
