Microspora pinout reference
The board exposes the main motor, sensing, communication, and power-monitoring signals in a compact pin map suitable for SimpleFOC firmware configuration.
Motor driver and sensing
Signal Pin Description
PHA_H PA10 High-side PWM for phase A
PHA_L PB15 Low-side PWM for phase A
PHB_H PA9 High-side PWM for phase B
PHB_L PB14 Low-side PWM for phase B
PHC_H PA8 High-side PWM for phase C
PHC_L PB13 Low-side PWM for phase C
ISENS_A PA0 Phase A current sense
ISENS_B PA1 Phase B current sense
ISENS_C PA2 Phase C current sense
VSENS PB11 Supply voltage sense input
Voltage divider scaling factor is 11.0 (4.7k / 47k)
Driver SPI interface
DRV_MOSI PB5_ALT1 DRV8316 SPI MOSI
DRV_MISO PB4_ALT1 DRV8316 SPI MISO
DRV_SCK PC10 DRV8316 SPI clock
DRV_CS PC4 DRV8316 SPI chip select
MT6701 magnetic encoder
ENC_SDO PA6 Encoder SPI MISO
ENC_NC PA7 Not connected (dummy MOSI)
ENC_CLK PA5 Encoder clock
ENC_CS PA4 Encoder chip select
CAN transceiver
CAN_RX PB8 CAN receive
CAN_TX PB9 CAN transmit
CAN_ENABLE PC13 CAN transceiver enable
LEDs and Buttons
LED PC6 User LED
BOOT PB8 Boot button (can be used in user applications, but not at the same time as CAN)
RESET - Reset button
PWR - Power indicator LED
Connectors
Microspora all connection
CAN connector
The board has a double 3-pin JST connector for daisy-chaining multiple boards using CAN. The order of pins is
Number Pin
1 GND
2 CAN_H
3 CAN_L
SPI connector
The board has an additional 6-pin JST connector for SPI, with the following pinout:
Number Pin Function
1 GND GND
2 3.3V 3.3V
3 PB5 MOSI
4 PB4 MISO
5 PC10 SCK
6 PC11 CS
This SPI header allows you to connect additional SPI devices to the board, such as an additional output shaft sensor or other SPI peripherals.
Note: This SPI bus is the same one used for the DRV8316 driver, so make sure to configure the driver before you use the SPI bus for other purposes.
I2C / Encoder / GPIO connector / Step/Dir
Finally, the board has a 5-pin JST connector for I2C, encoder, and GPIO. The pinout is as follows:
Number Signal I2C UART Encoder / timer PWM Step/dir
1 GND - - - - -
2 3.3V - - - - -
3 PA14 SDA (I2C1) RX (UART2) TIM8_CH2 PWM input (TIM8_CH2) Direction (PA14)
4 PA15 SCL (I2C1) TX (UART2) TIM8_CH1 PWM input (TIM8_CH1) Direction (PA15)
5 PB6 - - TIM8_ETR Direction (PB6) Step input (TIM8_ETR)
So this connector can be used for I2C, encoder, or GPIO depending on your application. Qwiic / Stemma-style cables can be used to connect to this connector, even though it is 5-pin instead of the usual 4-pin. For most cases the 4-pin stemma cable will work fine.
