Connecting the hardware to SimpleFOC-microspora
SimpleFOC-microspora is an all-in-one motor controller. It combines an STM32G431CBU6 microcontroller, a DRV8316 6-PWM motor driver, an MT6701 magnetic encoder, current sensing, voltage sensing, USB-C, CAN, SPI, and a multifunction 5-pin header.
Microspora all connection
Motor connection
The board supports both BLDC motors and stepper motors through the hybrid stepper mode.
Microspora motor connection
Using BLDC motors is easy with this board, simply connect the three motor phases to the corresponding outputs.
For steppers, first identify the phases A and B of the motor. Then connect the A+ and B+ to the outside motor terminals, while the A- and B- are connected together to the inside motor terminal.
Read a deeper dive in Hybrid Stepper mode
Motor phase resistance considerations.
This driver is not suitable for very low resistance BLDC motors, typically those below 0.1Ω. The RDS(on) of the DRV8316 MOSFETs is around 100mΩ which is comparable to the high-power BLDC motors and can cause significant heating and power loss. This driver's max current is around 8A, so take this in consideration when selecting motors and operating conditions.
Magnet and mounting
The MT6701 magnetic encoder sits on the bottom side of the board, in the centre. The board mounts on the back of the motor with the sensor facing the motor shaft, and a magnet on the end of the shaft gives the position of the rotor.
The magnet
Use a 6mm diametrically magnetized magnet: the north and south poles are on the two halves of the round face, so the field rotates as the shaft turns.
Diametric, not axial
Axially magnetized magnets (poles on the two flat faces) look exactly the same, but they won’t work: the field doesn’t change as the magnet turns, so the sensor can’t measure the angle. Always check the magnetization when buying magnets.
Fix the magnet to the end of the motor shaft, for example with a drop of glue or with a 3D-printed holder. Steel shafts hold the magnet magnetically, but glue is still recommended so it can’t move during operation.
Air gap and centring
  • Air gap: keep 1-2mm between the magnet and the sensor chip. Too far, and the field is too weak for a reliable reading. Too close, and the magnet may touch the board when the motor heats up or vibrates.
  • Centring: the magnet should be centred right under the sensor. A small offset adds a periodic error to the measured angle, which shows up as torque ripple and noise in velocity control.
Small leftover centring errors can be compensated in software with the CalibratedSensor from the SimpleFOCDrivers library, see calibrating the sensor.
If the sensor reads nothing or initFOC() fails, check the magnet first: wrong magnetization, too large a gap or a badly centred magnet are the most common causes. Use the sensor test to check the readings before running the motor.
Mounting the board
Microspora mounting holes
The board can be mounted using the three mounting slots, which accept M2 and M3 screws. They allow the board to be attached directly to the back of many common motors, at a distance that sets the air gap to the magnet. If the hole distances do not match your motor, a simple 3D-printed adapter can be used instead.
The minimal hole distance is 22mm (corresponding to the holes of GM2804 and GM5208 motors), and the maximal hole distance is 28mm (corresponding to the holes of GM4108 motors).
Microspora on a large gimbal motorMicrospora on a medium gimbal motorMicrospora on a NEMA17 stepper
When designing an adapter or enclosure, you can use the 3D model of the board (STEP format) to get the sensor position and the air gap right.
Power supply
The board allows a range of power-supply voltage from 5-35V DC. The DRV8316 provides an onboard 5V buck output for the board and supported peripherals. But the maximal current it can supply is limited to around 200mA. Which is typically sufficient for sensors and low-power peripherals. Only 3.3V output is available for peripherals using the JST connectors.
CAN connection
Microspora can connection
The board has two 3-pin JST connectors for CAN daisy chaining. They are electrically connected so additional Microspora boards can be connected in a chain.
Pin Signal
1 GND
2 CAN_H
3 CAN_L
Use a 120Ω termination resistor at the physical ends of the CAN network. To disable the termination resistor, use a sharp hobby knife (e.g. X-Acto) to cut the trace connecting the resistor. You can always re-enable it by soldering the solder pad back together.
The firmware examples use a 1Mbps CAN bus and include Python scripts for scanning the bus and sending motor commands. See the CAN scripts.
The CAN transceiver uses the following MCU signals:
Signal Pin Description
CAN_RX PB8 CAN receive
CAN_TX PB9 CAN transmit
CAN_ENABLE PC13 CAN transceiver enable
6-pin SPI header
Microspora 6-pin connection
The 6-pin JST header exposes SPI3. This bus is shared with the DRV8316 driver, so configure the driver before using the header for another SPI device.
Pin Signal Function
1 GND Ground
2 3.3V 3.3V output
3 PB5 MOSI
4 PB4 MISO
5 PC10 SCK
6 PC11 CS
5-pin multifunction header
Microspora 5-pin connection
The 5-pin JST header can be used for I2C, UART, an external encoder, PWM, step/dir, or general-purpose I/O. It is compatible with many Qwiic and STEMMA QT cables; when using a 4-pin cable, leave the fifth signal unconnected as appropriate for the selected function.
Pin Signal I2C UART Encoder / timer PWM Step/dir
1 GND - - - - -
2 3.3V - - - - -
3 PA14 SDA (I2C1) RX (UART2) TIM8_CH2 PWM input (TIM8_CH2) Direction (PA14)
4 PA15 SCL (I2C1) TX (UART2) TIM8_CH1 PWM input (TIM8_CH1) Direction (PA15)
5 PB6 - - TIM8_ETR Direction (PB6) Step input (TIM8_ETR)
LEDs
The board has the following LEDs:
  • Power LED: indicates the power-supply is connected.
  • User LED: A LED on PC6, can be controlled by the user.
But you can also add many more using auxiliary JST connectors, especially if using STEMMA QT or Qwiic compatible devices.
Programming the board
The board is programmed over USB-C in DFU mode, no external programmer needed. See the toolchain guide for PlatformIO and Arduino IDE setup and the DFU steps.
Toolchain and flashing Write your own firmware
