Writing the code for SimpleFOC-microspora
Before starting, make sure you have set up the toolchain and connected the hardware.
Everything the board needs is on board: the DRV8316 driver, the MT6701 magnetic sensor, current sensing and supply voltage sensing. The code below brings them up one at a time, so if something doesn’t work you know exactly which part to look at.
- Step 1. Testing the sensor
- Step 2. Testing the driver
- Step 3. Open-loop motor test
- Step 4. Closed-loop control
- Step 5. FOC current control
- Step 6. Running FOC from a timer
- Complete example
Toolchain and flashing Pinout reference CAN communication
The MT6701 sensor is connected to SPI1 using SSI mode. It needs its own SPIClass instance because the default SPI pins are not the ones used on this board.
#include <SimpleFOCDrivers.h>
#include "encoders/mt6701/MagneticSensorMT6701SSI.h"
// MT6701 on SPI1: MOSI (not connected), MISO, SCK
SPIClass SPI_1(PA7, PA6, PA5);
SPISettings mt6701_settings(10000000, MT6701_BITORDER, SPI_MODE2);
MagneticSensorMT6701SSI sensor(PA4, mt6701_settings); // CS = PA4
Serial.begin(250000);
_delay(3000);
sensor.init(&SPI_1);
Serial.println(sensor.getAngle());
_delay(10);
Turn the motor by hand. The angle should change smoothly and increase by about 6.28 (2π) per turn. Make sure there is a 6mm diametrically magnetized magnet on the motor shaft, centred under the sensor with a 1-2mm gap, see magnet and mounting.
Read more about testing the sensor
The DRV8316 is driven with 6 PWM signals and configured over SPI3. The SPI3 pins need the _ALT1 variants, so again a separate SPIClass instance is used.
#include "drivers/drv8316/drv8316.h"
// DRV8316 on SPI3: MOSI, MISO, SCK
SPIClass SPI_3(PB5_ALT1, PB4_ALT1, PC10);
DRV8316Driver6PWM driver(PA10, PB15, PA9, PB14, PA8, PB13, PC4, false); // 6 PWM pins, CS = PC4
driver.pwm_frequency = 25000;
driver.init(&SPI_3);
driver.setPWMMode(PWM6_Mode);
driver.setBuckVoltage(VB_5V); // onboard 5V buck output
driver.setOCPMode(NoAction);
If the driver initialises without reporting a fault, it is ready.
Measuring the supply voltage
The supply voltage is measured on PB11 through a 4.7k / 47k divider (scaling factor 11). Use it to set voltage_power_supply automatically and to refuse to start on a missing or too low supply:
float readSupply() {
analogReadResolution(12);
return analogRead(PB11) * 3.3f / 4095.0f * 11.0f;
float voltage = readSupply();
while (voltage < 8.0f) {
Serial.println("Supply voltage too low!");
driver.voltage_power_supply = voltage;
Now add a motor and run it in open loop. This checks the driver and the motor wiring without involving the sensor.
For a BLDC motor:
BLDCMotor motor = BLDCMotor(pole_pairs);
For a stepper motor in hybrid stepper mode, wired as described in the hardware guide:
HybridStepperMotor motor = HybridStepperMotor(pole_pairs); // steps per revolution / 4, e.g. 50 for a 200-step NEMA17
Stepper phase order
The common stepper phase is connected to the middle terminal (PHB), and
HybridStepperMotorexpects the common phase to be the 3rd driver phase. So for steppers, swap the B and C pins in the driver constructor:DRV8316Driver6PWM driver(PA10, PB15, PA8, PB13, PA9, PB14, PC4, false); // A, C, B (common)
// ... driver init
motor.voltage_limit = 2; // start low!
motor.move(5); // 5 rad/s
Read more about the open-loop test
Link the sensor to the motor and call initFOC(). This aligns the sensor with the motor’s electrical angle.
// ... sensor and driver init
motor.move(5);
Read more about closing the loop
The DRV8316 has built-in current sense amplifiers on all three phases, connected to PA0, PA1, PA2. The amplifier gain is set over SPI and must match the gain given to LowsideCurrentSense (in mV/A).
setCurrentSenseGain() | LowsideCurrentSense gain | Approx. measurable range |
Gain_0V15 | 150.0f | ±11A |
Gain_0V3 | 300.0f | ±5.5A |
Gain_0V6 | 600.0f | ±2.7A |
Gain_1V2 | 1200.0f | ±1.4A |
Pick the most sensitive gain that still covers the peak current of your motor.
For steppers, only the two motor phases are measured, in the same order as the driver: LowsideCurrentSense current_sense(300.0f, PA0, PA2);
LowsideCurrentSense current_sense(300.0f, PA0, PA1, PA2);
// ... driver init
driver.setCurrentSenseGain(Gain_0V3); // must match the 300 mV/A above
current_sense.skip_align = true; // the phase order is fixed on the board
// ... motor.init(), motor.initFOC()
Read more about current control
Step 6. Running FOC from a timer interrupt
For the most consistent performance, run loopFOC() and move() from a hardware timer at a fixed rate, and keep communication and monitoring in loop().
// ... everything above
HardwareTimer* timer = new HardwareTimer(TIM6);
timer->setOverflow(10000, HERTZ_FORMAT); // 10kHz
timer->attachInterrupt([]() {
timer->resume();
motor.monitor();
Timer choice
Don’t use TIM1 (used for the motor PWM) or TIM8 (used by the 5-pin header in encoder, PWM input and step/dir modes). The basic timers TIM6 and TIM7 are good choices.
Complete example
Here is everything above put together: FOC current control in torque mode, running at 10kHz from a timer, with the Commander interface on USB serial so you can change the target and tune the motor at runtime.
Before uploading, set POLE_PAIRS for your motor and adjust the voltage and current limits.
#define POLE_PAIRS 7
// SPI buses
SPIClass SPI_1(PA7, PA6, PA5); // MT6701 sensor: MOSI (not connected), MISO, SCK
SPIClass SPI_3(PB5_ALT1, PB4_ALT1, PC10); // DRV8316 driver: MOSI, MISO, SCK
// MT6701 magnetic sensor
// DRV8316 driver, 6 PWM
// current sensing, gain must match driver.setCurrentSenseGain() below
// motor
BLDCMotor motor = BLDCMotor(POLE_PAIRS);
return analogRead(PB11) * 3.3f / 4095.0f * 11.0f; // 4.7k / 47k divider
_delay(3000); // give the USB serial time to connect
pinMode(PC6, OUTPUT);
digitalWrite(PC6, HIGH); // LED on during initialisation
// wait for a valid supply voltage
Serial.print("Supply voltage: ");
Serial.println(voltage);
// sensor
// driver
driver.dead_zone = 0.001f;
driver.setSlew(Slew_200Vus);
driver.setCurrentSenseGain(Gain_0V3); // 300 mV/A
// current sense
// control config
motor.voltage_limit = 6; // [V]
motor.current_limit = 2; // [A]
motor.velocity_limit = 50; // [rad/s]
// monitoring (start/end chars match the commander ID 'M' for the webcontroller)
motor.monitor_start_char = 'M';
motor.monitor_end_char = 'M';
motor.monitor_downsample = 0; // disable monitoring
if (!motor.init()) {
Serial.println("Motor init failed!");
return;
if (!motor.initFOC()) {
Serial.println("FOC init failed!");
return;
motor.target = 0; // [A]
Serial.println("Motor ready. Set the target with: M0.5");
digitalWrite(PC6, LOW); // LED off when ready
// run FOC at 10kHz from a hardware timer
timer->resume();
motor.monitor();
Open the serial monitor at 250000 baud and send M0.5 to apply 0.5A of torque current. See the Commander interface docs for all the commands, e.g. changing the motion control mode or tuning the PID controllers.
Using the web controller
The example is ready for the SimpleFOC web controller as is: open webcontroller.simplefoc.com in a Chromium-based browser, click Connect, select the board’s serial port at 250000 baud, and you can control, tune and plot the motor in real time without writing any extra code.
Going further
Measuring the motor parameters and auto-tuning the current loop
Since the board has current sensing, the library can measure the motor phase resistance and inductance for you, and then use them to tune the current controller automatically. Add this after motor.initFOC():
motor.characteriseMotor(3.0f); // measure R and L, applying 3V
motor.tuneCurrentController(500.0f); // tune the current PID for a 500Hz bandwidth
The measured values are printed to the serial monitor. Once you have them, you can set them directly (motor.phase_resistance, motor.axis_inductance.d and motor.axis_inductance.q) and skip the measurement on every startup.
Motor characterisation Tuning the current loop
Calibrating the sensor
If the magnet is not perfectly centred above the MT6701, the measured angle will have a small periodic error that shows up as torque ripple. The SimpleFOCDrivers library includes a CalibratedSensor that measures this error once and compensates for it with a lookup table:
#include "encoders/calibrated/CalibratedSensor.h"
CalibratedSensor sensor_calibrated = CalibratedSensor(sensor);
// ... sensor, driver and motor.init() as before
sensor_calibrated.voltage_calibration = 2.0f; // voltage applied during calibration
sensor_calibrated.calibrate(motor);
motor.linkSensor(&sensor_calibrated); // use the calibrated sensor from now on
CalibratedSensor documentation
CAN and the reference firmware
To control the board over CAN as well, add the code from the CAN communication page.
The Microspora firmware repository contains the reference firmware with CAN, motor characterisation and sensor calibration.
Get the reference firmware on GitHub
