β˜… Loading...
SimpleFOC-microspora v1.7
License: MIT GitHub release (latest by date) GitHub Release Date
SimpleFOC-microspora side viewSimpleFOC-microspora top viewSimpleFOC-microspora bottom viewSimpleFOC-microspora board photo
SimpleFOC-microspora is an all-in-one BLDC and stepper motor controller for the SimpleFOClibrary. The microcontroller, motor driver, magnetic encoder, current sensing and CAN transceiver all fit on a 33x34mm board that mounts directly on the back of the motor. Connect a motor, a power supply and a USB-C cable, and you are ready to go.
The board is a fork of the MicroSpora board by RamBros, adapted for the SimpleFOC ecosystem.
πŸ“’ Available now from Makerfabs: See more on makerfabs.com
Get started with your microspora board Order from Makerfabs GitHub project
Features
  • Plug & play with the Arduino SimpleFOClibrary
  • MCU: STM32G431CBU6 (Cortex-M4, 170MHz, FPU)
  • Motor driver: DRV8316C
    • Power supply: 5-35V
    • Maximum current: ~8A
    • 6-PWM mode, configured over SPI
  • BLDC and stepper motors (stepper in hybrid stepper mode)
  • Sensing:
    • MT6701 14-bit magnetic encoder, on the bottom of the board, right above the motor shaft
    • 3-phase low-side current sensing, with SPI-configurable gain
    • Supply voltage sensing
  • Connectivity:
    • USB-C for programming (DFU, no programmer needed) and serial communication
    • CAN with two daisy-chain JST connectors and a cuttable 120Ξ© termination
    • 6-pin SPI JST connector
    • 5-pin I2C / UART / encoder / step-dir JST connector, Qwiic / STEMMA QT compatible
  • Compact: 33x34mm, with mounting slots for most gimbal motors (GM2804 to GM5208) and NEMA17 steppers
  • Fully open-source:
What can you do with it?
Documentation
Guide What’s inside
Connecting the hardware Motor wiring, power supply, connectors, mounting
Toolchain and flashing PlatformIO and Arduino IDE setup, DFU upload
Writing the code Step-by-step guide to a complete BLDC or stepper example
CAN communication Controlling one or more boards over CAN
Pinout reference All MCU pins and connector pinouts
Fabrication Ordering the board from JLCPCB, with the full BOM
Release log
Release Date Description
v1.7 2026-06 Sensor moved to the bottom side, much better performance for stepper motors
v1.6 2026-04 JST pinout optimised for Qwiic / STEMMA QT compatibility, reset button reintroduced
v1.5 2026-01 Pinout refinements
v1.4 2025-12 CAN daisy-chain support, two additional JST connectors for SPI and I2C / encoder / GPIO
v1.2 2025-07 CAN and additional GPIO JST connectors, from 6-layer to 4-layer PCB
v0.1 2025-05 Initial public release of the MicroSpora board by RamBros
How to get hold of the SimpleFOC-microspora
Questions, projects, ideas? Join the discussion on the SimpleFOC community forum.
