CAN communication
CAN is a robust bus for connecting several motor controllers with just two wires, which makes it the natural choice for robots and multi-axis machines. The CANCommander from the SimpleFOCDrivers library gives every SimpleFOC node an address on the bus, and lets you read and write any motor value using the same registers as the serial protocols.
Source and protocol README Examples
Requirements
- A microcontroller with a CAN peripheral and a CAN transceiver, for example an STM32 with FDCAN (like the STM32G4) and a TJA1051, SIT1042 or similar transceiver.
- The SimpleCANio library, which provides the hardware layer.
- 120Ω termination resistors at both physical ends of the bus.
On STM32 with the Arduino framework, the FDCAN HAL module has to be enabled, e.g. in PlatformIO:
build_flags = -D HAL_FDCAN_MODULE_ENABLED
Usage
#include <SimpleFOCDrivers.h>
#include "comms/can/CANCommander.h"
#include "SimpleCANio.h"
CANio can(CAN_RX_PIN, CAN_TX_PIN); // see SimpleCANio for the optional pins
CANCommander commander(can, 0x12); // this node's address on the bus
// ... motor setup, motor.init(), motor.initFOC()
commander.init();
commander.addMotor(&motor);
commander.run();
Every node needs a unique address from 0x00 to 0xFE. Address 0xFF is the broadcast address: messages sent to it are received by all nodes.
The protocol
The protocol uses 29-bit extended CAN IDs. The address is in the most significant bits, so each node can filter its messages in hardware:
Bits [27:20] Node address (8 bits)
Bits [19:16] Packet type (4 bits)
Bits [15:8] Register number (8 bits)
Bits [7:0] Motor index (8 bits)
| Packet type | Value | Data |
| Read request | 0x1 | empty |
| Write request | 0x2 | the new value |
| Read response | 0x3 | the register value |
| Sync | 0xF | optional |
Values are sent as raw little-endian binary: float as 4 bytes IEEE 754, integers as 1 or 4 bytes. A frame carries at most 8 bytes, so up to two floats. Larger values are split into separate register reads.
For example, to set the target of motor 0 on node 0x12 to 2.0, send a write request with ID 0x12 << 20 | 0x2 << 16 | REG_TARGET << 8 | 0 and the 4 bytes of the float 2.0f as data. If echo is enabled on the node, it answers with a read response containing the new value.
The full register list is in the register reference.
Controlling nodes
From a computer
With a USB-CAN adapter, you can control the nodes from Python using PySimpleFOC, which implements the protocol on top of python-can. On Linux, most USB-CAN adapters (e.g. CANable) show up as a SocketCAN interface:
sudo slcand -o -c -s8 /dev/ttyACM0 can0 # -s8 = 1Mbps
sudo ip link set can0 up
From another microcontroller
CANNodeInteractor is the counterpart of CANCommander for a node that sends requests, for example a main controller coordinating several motor nodes:
CANNodeInteractor interactor(can, 0x01); // this node's own address
// read the status of motor 0 on node 0x12
interactor.sendRead(0x12, REG_STATUS, 0);
if (interactor.waitForResponse()) {
uint8_t status = 0;
interactor.decodeResponseUint8(status);
// set the target of motor 0 on node 0x12
interactor.sendWriteFloat(0x12, REG_TARGET, 1.2f, 0, true);
A node can run both a CANCommander and a CANNodeInteractor, to have motors of its own and talk to other nodes at the same time. The interactor handles one request at a time, with a response timeout.
Custom registers
You can expose your own values over CAN by adding registers from REG_CUSTOM_START (0xE0) upwards, after commander.init():
float my_value = 0;
bool readMyValue(RegisterIO& io, FOCMotor* motor) { io << my_value; return true; }
bool writeMyValue(RegisterIO& io, FOCMotor* motor) { io >> my_value; return true; }
commander.init();
commander.addCustomRegister(0xE0, 4, readMyValue, writeMyValue); // 4 bytes
Keep custom registers to 8 bytes or less, so they fit in a single CAN frame.
