- Ordering a SimpleFOC board from JLCPCB
- Board settings at a glance
- Step 1: Download the files from GitHub
- Step 2: Upload the Gerber files
- Step 3: PCB options
- Step 4: PCB assembly
- Step 5: Upload the BOM and the pick and place file
- Step 6: Check the BOM
- Step 7: Check the placement
- Step 8: Order
- Ordering from EasyEDA instead
- Board specific notes
- Other PCB assembly services
All SimpleFOC boards are open source, and their GitHub repositories contain everything needed to have them made: the Gerber files, the bill of materials (BOM) with an LCSC part number for every component, and the pick and place (CPL) file. This means you can order any of them fully assembled from JLCPCB in about 10 minutes.
This page shows the process once, with the QtFOC as the example, followed by the settings that are specific to each board.
Make it or buy it?
JLCPCB makes at least 2 assembled boards per order (usually 5), and you pay a setup fee for each order. Unless you need several boards, or you want to modify the design, buying an assembled and tested board from Makerfabs is usually cheaper and quicker.
| Board | GitHub repository | Layers | Assembly side | Notes |
| SimpleFOCMini v2.3 | SimpleFOCMini | 2 | Top | Mini fabrication |
| QtFOC v1.6 | QtFOC | 2 | Top | - |
| SimpleFOCShield v4.1 | Arduino-SimpleFOCShield | 4 | Top | Don’t place parts on the SC... solder pads, see below |
| SimpleFOC DriveShield v1.8 | SimpleFOC-DriveShield | 4 | Top | Choose 2oz outer copper, see below |
| SimpleFOC-microspora v1.7 | SimpleFOC-microspora | 4 | Both sides | CAN transceiver often needs a replacement, see the microspora fabrication guide |
All the boards use fine-pitch parts (the DRV8316 or DRV8320H in a 0.5mm pitch QFN package with a thermal pad), so they are not well suited for hand soldering. The steps below use the JLCPCB PCB assembly (PCBA) service.
Open the board’s GitHub repository from the table above, click Code > Download ZIP, and unzip it.
You will need three things from it:
- The Gerber files: the
Gerberfolder. JLCPCB wants them as a single zip file, so zip theGerberfolder (for exampleGerber.zip). - The BOM: the
BOM_....csvfile (or.xlsx). - The pick and place file: the
PickAndPlace_....csvfile (or.xlsx), in the pick and place folder.
Go to jlcpcb.com and click Get Instant Quote.
Click Add gerber file and select the Gerber.zip you made.
Step 3: PCB options
JLCPCB shows the board and detects its size and number of layers. Check that the layers match the table above.
The defaults are fine for the rest, with one exception: for the DriveShield, set the outer copper weight to 2oz (in the PCB specifications further down).
Scroll to the bottom of the page and enable PCB Assembly. Then:
- PCBA type: Standard
- Assembly side: Top Side, or Both Sides for the microspora
- PCBA Qty: how many of the PCBs should be assembled, 2 at least
Click Next, and Next again on the PCB preview.
Click Add BOM File and select the BOM_....csv file, then Add CPL File and select the PickAndPlace_....csv file.
Then click Process BOM & CPL.
JLCPCB may warn that some parts won’t be assembled because they are not in the BOM. These are the through-hole headers and terminals (for the QtFOC: P2, H1, TB_PWR1 and U4, the XIAO / QT Py footprint), which you solder yourself, so click Continue.
JLCPCB lists all the components, matched to its parts library, and checks that they are in stock. All the parts should be selected.
- A part is out of stock: click the search button next to it and choose an equivalent part. The board pages list the known replacements, for example the CAN transceiver on the microspora.
- Never unselect the driver, the current sense amplifiers, or the passive components.
Click Next.
JLCPCB shows a preview of the assembled board. Check that all the parts are there, and pay attention to the orientation of the chips (the pin 1 dot), the LEDs and the diodes. If you’re not sure, you can ask JLCPCB to confirm the placement before production, with Confirm Parts Placement: Yes in step 4.
Click Next.
Step 8: Order
Choose the product description, for example Research/Education/DIY/Entertainment > DIY, and click Save to Cart. Then go through the payment and shipping in the cart.
For example, 5 assembled QtFOC boards cost about $110 in November 2026 ($4 for the PCBs, $106 for the assembly), plus about $23 for shipping. That is about $25 per board, most of it the setup and feeder fees, which are the same whatever the number of boards.
You can also send a board to JLCPCB straight from its EasyEDA project, without downloading anything. Open the project linked on the board’s page, open the PCB file, and click Fabrication > One-click Order PCB/SMT (EasyEDA Standard: Mini, QtFOC, DriveShield) or Export > PCB/FPC One-Click Prototyping (EasyEDA Pro: Shield, microspora). JLCPCB opens with the board already uploaded, and you continue from step 3. The microspora fabrication guide shows this way step by step.
SimpleFOCMini v2
- 2-layer board with all the parts on the top side.
- The pin headers are not in the BOM, solder them yourself.
- More details in the Mini fabrication guide.
QtFOC
- 2-layer board with all the parts on the top side, including the SPI JST connector.
- The XIAO / QT Py headers and the motor and power terminals are not in the BOM, solder them yourself.
SimpleFOCShield v4
- 4-layer board, assembled on the top side.
- The pick and place file also lists the configuration solder pads (
SC...designators) on the bottom side. They are only copper pads, not components, so don’t place any parts for them. - The Arduino stacking headers, the encoder header and the terminals are through-hole parts, solder them yourself.
- More details in the Shield v4 fabrication guide.
- Choose 2oz outer copper. The board runs noticeably cooler with it, see the thermal measurements. The boards made by Makerfabs use 2oz too.
- The Arduino headers and the terminals are through-hole parts, solder them yourself.
- 4-layer board, assembled on both sides: the MT6701 magnetic encoder is on the bottom.
- The CAN transceiver is often out of stock. The microspora fabrication guide shows the whole process step by step, with the replacement part.
Any PCBA service works with the Gerber, BOM and pick and place files from the GitHub repositories. The part numbers in the BOMs are LCSC numbers, so with other services you may need to look up the manufacturer part numbers (also in the BOM) or choose replacements.
Questions about fabricating a board? Ask on the SimpleFOC community forum.
