Fabrication guide for SimpleFOC microspora
Here is a quick guide how to fabricate the SimpleFOC microspora board. The board has been designed using the EasyEDA software that makes it very easy to fabricate using the JLCPCB website.
Step by step guide
First step is to go to the EasyEDA’s project library (EasyEDA) and open the SimpleFOC microspora project in the EasyEDA editor.
EasyEDA editor
Then double click on the PCB file Microspora_Board_4layer
To export the gerber files click on Export>PCB One-Click Prototyping
The pop-up will show up asking if you want the Design Rule check and click Yes, Check DRC.
Once the files are generated you the new pop-up will show up and there you just click Confirm.
JLCPCB site
You will be redirected to the JLCPCB site where you will be able to see your board outline.
Go to the bottom of the page and enable PCB Assembly
Select PCBA type as Standard
And select double-sided assembly: Both Sides
Then click Next
And NEXT again:
Now you will come to the BOM selection screen. There may be some components that are not available in any given time, but they are usually always available.
The one component that is commonly missing is the CAN transceiver (CA-IF1044VD-Q1), you can replace it with SIT1042ATK/3. First click on the Search button
Then type the SIT1042ATK/3 and click Select
Then you should have all components, and you can click NEXT
Check visually that all components are populated on the board and click NEXT
At the end set the use of your board for example Research/Education/DIY > DIY
And Save to Cart
Fabrication price
Price of a 5 board batch at JLCPCB website is around 225$ (November 2026), making it around 45$ per board, which is very expensive. In August of 2026 15 board price was around 350$, making it about 23$ per board, so timing might be important when ordering.
BOM file
Here is the complete list of BOM components
| Designator | Comment | Footprint | JLCPCB Part # |
| USB1 | TYPE-C16PIN | USB-C-SMD_TYPE-C-6PIN-2MD-073 | C2765186 |
| U8 | MT6701QT-STD | QFN-16_L3.0-W3.0-P0.50-TL-EP1.7 | C2913974 |
| R22,R23,R24,R26,R29,R31,R33 | 330Ω | R0402 | C25104 |
| U1 | DRV8316CRRGFR | VQFN-40_L7.0-W5.0-P0.50-BL-EP5.7 | C5447274 |
| SW2,SW3 | TSA002A3512A02 | SW-SMD_BZCN_TSA002A35XXX | C2888932 |
| R21,R27,R28,R32 | 10kΩ | R0402 | C25744 |
| R19,R20 | 100kΩ | R0402 | C25741 |
| L1 | 47uH | IND-SMD_L3.0-W3.0_PRS3015 | C702780 |
| CN13 | SM05B-SRSS-TB(LF)(SN) | CONN-SMD_SM05B-SRSS-TB-LF-SN | C136657 |
| LED4 | red | LED0603-RD | C2286 |
| R30 | 120Ω | R0402 | C25079 |
| C27,C30,C34,C36,C38,C42,C43,C47,C48,C50,C51 | 100nF | C0402 | C307331 |
| Q1 | AO3401A | SOT-23_L2.9-W1.3-P1.90-LS2.4-BR | C15127 |
| U9 | STM32G431CBU6 | UFQFPN-48_L7.0-W7.0-P0.50-BL-EP | C529356 |
| X1 | 16MHz | CRYSTAL-SMD_4P-L2.5-W2.0-BL | C2875244 |
| C28,C29 | 10pF | C0402 | C32949 |
| U11 | CA-IF1044VD-Q1 | DFN-8_L3.0-W3.0-P0.65-BL-EP2.45 | C5382546 |
| D1 | BZT52B5V1S | SOD-323_L1.7-W1.3-LS2.6-RD | C19077434 |
| LED2 | yellow | LED0603-RD-YELLOW | C2287 |
| C31,C32,C33 | 22pF | C0402 | C1555 |
| C23,C25,C26,C37,C40,C41 | 1uF | C0402 | C52923 |
| CN4,CN5 | SM03B-SRSS-TB(LF)(SN) | CONN-SMD_SM03B-SRSS-TB-LF-SN-P | C160403 |
| CN7 | SM06B-SRSS-TB(LF)(SN) | CONN-SMD_SM06B-SRSS-TB-LF-SN | C160405 |
| R2,R3,R16,R17,R25 | 5.1kΩ | R0402 | C25905 |
| D3 | 1N4148WS | SOD-323_L1.8-W1.3-LS2.5-RD | C2128 |
| C35,C54 | 22uF | C0603 | C59461 |
| C44,C45,C46,C52,C57 | 10uF | C0805 | C6119892 |
| U10 | XC6206P332MR-G | SOT-23-3_L2.9-W1.6-P1.90-LS2.8-BR | C5446 |
