Settings storage
Every time a SimpleFOC motor starts, initFOC() moves the motor to find the sensor direction and the zero electrical angle. Settings storage saves this calibration, and any other settings you choose such as PID gains and limits, to non-volatile memory. On the next startup the values are loaded, and the motor is ready immediately without moving.
Settings storage is based on the registers, so any register that can be both read and written can be saved.
Supported storage
| Storage | Class | Notes |
| STM32 flash | STM32FlashSettingsStorage | STM32G4 on-board flash |
| SAMD NVM | SAMDNVMSettingsStorage | SAMD on-board flash or RWWEE memory |
| CAT24 I2C EEPROM | CAT24I2CFlashSettingsStorage | External EEPROM, unfinished |
The storage classes share the same interface, so the code below works with any of them. It’s also easy to add your own storage by extending the SettingsStorage class.
Usage
The pattern is: set your defaults, try to load the settings, initialise, and save the settings if they weren’t loaded.
#include <SimpleFOCDrivers.h>
#include "settings/stm32/STM32FlashSettingsStorage.h"
STM32FlashSettingsStorage settings = STM32FlashSettingsStorage();
// 1. initialise the settings early
settings.addMotor(&motor);
settings.init();
// 2. set your defaults
motor.voltage_limit = 6;
// 3. try to load the saved settings, overwriting the defaults
SettingsStatus loadStatus = settings.loadSettings();
// 4. initialise as usual
// ... sensor, driver
motor.initFOC(); // skips the alignment if the calibration was loaded
// 5. save if nothing was loaded yet
if (motor.motor_status == FOCMotorStatus::motor_ready && loadStatus != SFOC_SETTINGS_SUCCESS) {
settings.saveSettings();
The first startup calibrates and saves. Every startup after that loads the calibration and skips the alignment movement.
Choosing what to save
By default, only the calibration is saved: REG_ZERO_ELECTRIC_ANGLE and REG_SENSOR_DIRECTION. To save more, pass a list of registers before settings.init():
SimpleFOCRegister settingsRegisters[] = {
REG_ZERO_ELECTRIC_ANGLE, REG_SENSOR_DIRECTION,
REG_VEL_PID_P, REG_VEL_PID_I, REG_VEL_PID_D, REG_VEL_LPF_T,
REG_VOLTAGE_LIMIT, REG_CONTROL_MODE, REG_TORQUE_MODE,
REG_PHASE_RESISTANCE, REG_KV, REG_INDUCTANCE
settings.setRegisters(settingsRegisters, sizeof(settingsRegisters) / sizeof(settingsRegisters[0]));
settings.init();
Saving REG_PHASE_RESISTANCE and REG_INDUCTANCE is useful together with motor characterisation: measure the motor once, save the result, and skip the measurement afterwards.
Saving from the Commander
To save values you tuned at runtime, for example with the web controller, add commands to save and load the settings:
void doSave(char* cmd) { settings.saveSettings(); }
void doLoad(char* cmd) { settings.loadSettings(); }
command.add('s', doSave, "save settings");
command.add('l', doLoad, "load settings");
Tune the motor, then send s to keep the values.
STM32 flash
STM32FlashSettingsStorage stores the settings in the STM32’s own flash memory. It currently supports STM32G4 MCUs (2kB flash pages). By default it uses the last page of the flash. To use another location, pass the address:
// 10kB below the end of the flash
STM32FlashSettingsStorage settings = STM32FlashSettingsStorage(FLASH_BASE + FLASH_SIZE - 10*1024);
Flash and reprogramming
Flash used for settings can’t be used by your program, so make sure your firmware doesn’t fill the whole flash. Also, uploading new firmware may erase the whole flash, including the settings, so the motor will calibrate again on the first startup after an upload. To avoid this, reserve the settings page in your board’s linker script.
Dual-bank flash configurations have not been tested.
