Low-Pass Filter Implementation v2.4+
The LowPassFilter class provides first-order low-pass filtering for noisy sensor measurements, particularly useful for velocity calculations that involve differentiation of position.
Class Definition
From common/lowpass_filter.h:
class LowPassFilter {
LowPassFilter(float Tf, float Ts = NOT_SET);
float operator() (float x);
float Tf; // Low pass filter time constant
float Ts; // Fixed sampling time (optional)
protected:
unsigned long timestamp_prev; // Last execution timestamp
float y_prev; // Filtered value in previous execution step
Constructor
LowPassFilter::LowPassFilter(float time_constant, float sampling_time)
: Tf(time_constant)
, Ts(sampling_time)
, y_prev(0.0f)
timestamp_prev = _micros();
Parameters:
Tf: Time constant (seconds) - determines filter response speedTs: Fixed sampling time (optional) - if not set, adaptive timing is used
Filter Algorithm
The operator() method implements the filtering:
float LowPassFilter::operator() (float x) {
// Initialize elapsed time with fixed sampling time Ts
float dt = Ts;
// If Ts not set, use adaptive sampling time
if(!_isset(dt)){
unsigned long timestamp = _micros();
dt = (timestamp - timestamp_prev)*1e-6f;
// Handle timing issues
if (dt < 0.0f) dt = 1e-3f;
else if(dt > 0.3f) {
y_prev = x;
timestamp_prev = timestamp;
return x;
// Calculate first-order filter
float alpha = Tf/(Tf + dt);
float y = alpha*y_prev + (1.0f - alpha)*x;
// Save for next iteration
y_prev = y;
return y;
Filter Equation
The discrete-time filter equation is:
\[y[k] = \alpha \cdot y[k-1] + (1-\alpha) \cdot x[k]\]Where the smoothing factor is:
\[\alpha = \frac{T_f}{T_f + \Delta t}\]Variables:
- \(y[k]\): Current filtered output
- \(y[k-1]\): Previous filtered output
- \(x[k]\): Current input sample
- \(T_f\): Filter time constant
- \(\Delta t\): Time since last sample
Characteristics
Time Constant (Tf)
The time constant determines the filterβs cutoff frequency:
\[f_c = \frac{1}{2\pi T_f}\]Effect on filtering:
- Smaller Tf (e.g., 0.001s = 1ms):
- Faster response
- Less smoothing
- Higher cutoff frequency (~159 Hz)
- More noise passes through
- Larger Tf (e.g., 0.1s = 100ms):
- Slower response
- More smoothing
- Lower cutoff frequency (~1.6 Hz)
- Better noise rejection
Adaptive vs Fixed Timing
Adaptive timing (Ts = NOT_SET):
- Measures actual time between calls
- Handles variable execution rates
- Adds timestamp overhead
- Includes safety checks for timing anomalies
Fixed timing (Ts set):
- Assumes constant sampling rate
- Faster execution (no time measurement)
- Suitable for fixed-rate control loops
- More predictable frequency response
Usage in SimpleFOC
Velocity Filtering
// In motor initialization
motor.LPF_velocity.Tf = 0.01; // 10ms time constant, fc β 16 Hz
// Automatic usage in shaftVelocity()
// in FOCMotor.cpp
float FOCMotor::shaftVelocity() {
return LPF_velocity(sensor->getVelocity());
Angle Filtering
// Position control with angle filtering
motor.LPF_angle.Tf = 0.005; // 5ms time constant
// in FOCMotor.cpp move() function
// Used in position control
current_sp = P_angle(shaft_angle_sp - LPF_angle(shaft_angle));
Current Filtering (FOC mode)
// Current measurement filtering
motor.LPF_current_q.Tf = 0.005; // 5ms
motor.LPF_current_d.Tf = 0.005; // 5ms
// in FOCMotor.cpp loopFOC() function
// Applied to measured currents
current.q = LPF_current_q(current_sense->getDCCurrent(electrical_angle));
current.d = LPF_current_d(0); // d-current filtered similarly
Tuning Guidelines
Step 1: Identify Noise Frequency
Measure or estimate the dominant noise frequency \(f_{noise}\):
- PWM noise: typically 10-50 kHz
- Sensor quantization: depends on encoder resolution and speed
- Electromagnetic interference: variable
Step 2: Set Cutoff Frequency
Choose cutoff frequency below noise but above signal:
\[f_c = \frac{f_{signal}}{2} \text{ to } f_{noise} \times 0.1\]Step 3: Calculate Time Constant
\[T_f = \frac{1}{2\pi f_c}\]Step 4: Verify Performance
Too much filtering (Tf too large):
- Sluggish response
- Phase lag in control
- Reduced performance at higher speeds
Too little filtering (Tf too small):
- Noisy measurements
- Control instability
- Audible noise from motor
Example: Velocity Filtering
For a motor with:
- Maximum velocity: 50 rad/s
- Control frequency: 1 kHz
- Noisy encoder with ~100 Hz noise
// Signal bandwidth: ~50 rad/s β 8 Hz
// Noise frequency: ~100 Hz
// Target cutoff: 15-20 Hz (between signal and noise)
float fc = 16.0; // Hz
float Tf = 1.0 / (2.0 * PI * fc); // β 0.01 seconds
Related Documentation
PID Controller Implementation Motion control implementation Torque control implementation
