PWM Modulation Strategies
After FOC calculates the desired phase voltages through coordinate transformations, these voltages must be converted into PWM signals. SimpleFOC supports multiple modulation techniques, each with different voltage efficiency and complexity.
Overview
All modulation types receive the same inputs from FOC:
  • \(U_q\) = torque voltage (q-axis)
  • \(U_d\) = flux voltage (d-axis)
  • \(\theta_{el}\) = electrical rotor angle
The modulation strategy determines how to apply these voltages to the motor phases.
Sinusoidal PWM (SinePWM)
The standard approach applies pure sinusoidal phase voltages.
Voltage utilization: \(U_{q,max} = 0.5 \cdot V_{supply}\)
Use when:
  • You want clean, simple waveforms
Supported motors:
  • BLDC motors (3-phase)
  • Stepper motors (2-phase)
  • Hybrid stepper motors (3-phase)
Space Vector PWM (SpaceVectorPWM)
SVPWM achieves better efficiency by modulating the common-mode voltage, enabling ~15% higher voltage output.
Voltage utilization: \(U_{q,max} = \frac{1}{\sqrt{3}} \cdot V_{supply} \approx 0.577 \cdot V_{supply}\)
Benefits:
  • 15% more available voltage than SinePWM
  • Better for battery-powered systems
  • Industry standard for high-performance drives
Centered vs non-centered:
  • Centered (modulation_centered = true): Default, symmetric waveforms
  • Non-centered (modulation_centered = false): Better for lowside current sensing (not recommended for general use)
Use when:
  • You need maximum torque at voltage limit
  • Battery power efficiency matters
  • Using lowside current sensing (not recommended for general use)
Supported motors:
Trapezoidal modulation (BLDC only)
Classical BLDC commutation using discrete 6-step or 12-step sequences.
Trapezoid_120
  • 6-step commutation (classical BLDC)
  • Sharpest transitions
  • Simplest computation
  • Highest torque ripple
Trapezoid_150
  • 12-step commutation
  • Smoother than 120°
  • Better efficiency
  • Lower torque ripple
Voltage utilization: \(U_{q,max} \approx 0.5 \cdot V_{supply}\)
Use when:
  • Motor has trapezoidal back-EMF
  • Minimal computation power available
  • Hall sensor commutation is desired
Note: Only supported for BLDC motors.
Comparison
Modulation Max Voltage Complexity Best For
SinePWM 0.5× Vsupply Low Learning, debugging, clean waveforms
SpaceVectorPWM 0.577× Vsupply Medium High efficiency, battery power, high speed
Trapezoid_120 0.5× Vsupply Very Low Minimal computation, classical BLDC
Trapezoid_150 0.5× Vsupply Low Trapezoidal back-EMF motors
Configuration
Power supply voltage
motor.voltage_power_supply = 12; // volts
Critical for PWM scaling and saturation detection.
Select modulation type
// For BLDC motors
motor.foc_modulation = FOCModulationType::SinePWM;
motor.foc_modulation = FOCModulationType::SpaceVectorPWM;  // Recommended for efficiency
motor.foc_modulation = FOCModulationType::Trapezoid_120;
motor.foc_modulation = FOCModulationType::Trapezoid_150;
// For stepper motors (SVPWM not supported)
// For hybrid stepper motors
SVPWM centering (if using SpaceVectorPWM)
motor.modulation_centered = true;  // Default: symmetric waveforms
// or
motor.modulation_centered = false; // For lowside current sensing
Motor support matrix
Motor Type SinePWM SpaceVectorPWM Trapezoid
BLDC ✓ ✓ ✓
Stepper ✓ ✗ ✗
Hybrid Stepper ✓ ✓ ✗
Choosing your modulation
For most users: Start with SinePWM (default, simplest)
Switch to SpaceVectorPWM if you need:
  • Maximum torque at voltage limit
  • Battery-powered efficiency
  • High-speed operation
Use Trapezoidal if:
  • Working with older BLDC drivers
  • Minimal CPU needed
What about saturation?
When voltage demand exceeds the modulation limit (\(U_q > U_{q,max}\)), the PWM duty cycles clip to the available range. The motor still works due to its inductance filtering the waveforms, but efficiency decreases and torque ripple increases.
For smooth operation, keep \(U_q\) below the theoretical limit of your chosen modulation type.
