Closed-Loop Control (Voltage-Based Torque)
⏱️ ~15 minutes
Now that you have a working motor and sensor, test closed-loop Field Oriented Control (FOC). This is the simplest closed-loop mode: torque control using voltage.
What’s Different From Open-Loop?
  • Open-loop: Spins motor at estimated angle, no feedback
  • Closed-loop: Uses sensor feedback to control torque precisely
  • Advantage: Stable, responsive, works across speed ranges
See motion control documentation for more details on control types and how/when to switch between them.
Select Your Motor + Driver + Sensor Combination
Sketch Template BLDC + 3PWM Driver + Encoder Stepper + 2PWM Driver + Encoder
Here is a template with TODO entries you can customize:
// TODO: motor instance
// TODO: driver instance
// TODO: sensor instance
  // enable more verbose output for debugging
  // TODO: sensor config
  // init the sensor
  // TODO: driver config
  // init the driver
  if(!driver.init()){
    Serial.println("Driver init failed!");
    return;
  // TODO: motor voltage alignment config
  // This voltage is used to align sensor with motor
  motor.voltage_sensor_align = 3; // start conservatively
  if(!motor.init()){
    Serial.println("Motor init failed!");
    return;
  if(!motor.initFOC()){
    Serial.println("FOC init failed!");
    return;
  // set the initial motor target
  motor.target = 2; // Volts
  // add target command M
  command.add('M', doMotor, "Motor");
  Serial.println(F("Set the target using serial terminal and command M:"));
BLDC motor with 3PWM driver and Encoder sensor:
BLDCMotor motor = BLDCMotor(TODO);
BLDCDriver3PWM driver = BLDCDriver3PWM(TODO, TODO, TODO, TODO);
Encoder encoder = Encoder(TODO, TODO, TODO);
  driver.voltage_limit = TODO;
  // driver init
  if(!driver.init()){
    return;
  // aligning voltage
  motor.voltage_sensor_align = 5;
  if(!motor.init()){
    return;
    return;
Stepper motor with 2PWM driver and Encoder sensor:
// Stepper motor & driver instance
StepperMotor motor = StepperMotor(TODO);
StepperDriver2PWM driver = StepperDriver2PWM(TODO, TODO, TODO, TODO);
  // driver init
  if(!driver.init()){
    return;
  // aligning voltage
    return;
Key Concepts
Sensor Alignment (motor.voltage_sensor_align)
During motor.initFOC(), the motor briefly spins to determine the sensor’s electrical zero position. The voltage used for this determines the alignment current.
  • Too low (~0.5V): May not rotate enough to align
  • Safe range (2-5V): Works for gimbal and small motors
  • Too high: Can draw excessive current
  • Start with 3V and adjust if needed
Motion Control Types
Once closed-loop works, you can switch modes with serial commands:
MC0  = Torque mode
MC1  = Velocity mode
MC2  = Angle mode
Then use M<value> to set target:
  • Torque: M2 = 2 Volts
  • Velocity: M6.28 = 1 rotation/second
  • Angle: M3.14 = half rotation
Testing
✓ What to expect
  1. During setup, motor will briefly spin (sensor alignment)
  2. Serial output: Motor ready. (not FOC init failed!)
  3. Motor smoothly responds to voltage changes via serial
  4. Motor feels firm (resistance) when you try to hold it
Basic Test
  1. Open serial terminal (115200 baud)
  2. Type M0 - motor should go to zero torque (no resistance)
  3. Type M1 - motor should produce light torque (you can feel it)
  4. Type M2 - motor should produce more torque
  5. Type M0 again - torque disappears
Velocity Control Test
  1. Type MC1 to switch to velocity mode
    If motor unstable (or very noisy) it will need velocity PI tuning (see troubleshooting below)
  2. Type M6.28 to spin 1 rotation/second
  3. Type M0 to stop
  4. Motor should accelerate smoothly and maintain speed
Angle Control Test
  1. Type MC2 to switch to angle mode
    If motor unstable (or very noisy) it will need angle P tuning (see troubleshooting below)
  2. Type M3.14 to rotate half turn
  3. Motor should move to that angle and hold it
Troubleshooting
FOC init failed?
  • Check sensor is working (from previous test)
  • Sensor alignment voltage too low: try increasing motor.voltage_sensor_align
  • Pole pair number wrong: verify from open-loop test
  • Sensor not aligned: see serial debug output for hints
Motor spins but is unstable/noisy?
  • Motor/driver connection loose: verify wiring
  • Velocity PI tuning needed: decrease motor.PID_velocity.P and motor.PID_velocity.I - see full tuning guide in Motion Control documentation
  • Angle P tuning needed: decrease motor.P_angle - see full tuning guide in Motion Control documentation
Motor doesn’t spin at all?
  • Check that driver initialized (look for Driver init failed!)
  • Verify sensor is reading (check debug output)
  • Pole pair number wrong: double-check from previous test
  • Try increasing motor.voltage_sensor_align to 1-2V minimum
Current too high during alignment?
  • Reduce motor.voltage_sensor_align
  • Try setting it with the phase resistance in mind:
    • If you motor has a phase resistance of 0.5 Ohms, then 3V will draw 6A during alignment (I = V/R). If this is too high for your motor or driver, reduce the voltage accordingly.
  • If resistance unknown, try measuring it - measuring guide
In torque mode, motor spins faster in one direction than the other?
  • This is usually the issue with the sensor alignment. Try increasing motor.voltage_sensor_align to ensure it fully aligns.
Some specific issues
  • AS5600 magnet polarisation issue - example issue - need to replace the magnet
Still having issues?
Browse through the SimpleFOC community forum, there might already be a solution for your specific hardware or issue. Also don’t hesitate to ask for help there!
What’s Next?
You now have a fully functional voltage based control system! If the performance of this control mode is sufficient for your application, you can start building on top of it with motion profiles, trajectory planning, and higher level feedback loops.
For Robotics/Automation
For Precision Applications
  • Tune PID parameters for your motor
  • Use angle mode for position control
  • See PID tuning guide
For Learning
More advanced control schemes
With voltage-based torque control working, you have a solid foundation! For more advanced control, current sensing or motor model based current estimation can improve overall performance a lot.
Once this works:
Relevant Documentation
