β˜… Loading...
Test Your Driver
⏱️ ~10 minutes
Once your sensor is working, test that your motor driver can initialize and output PWM signals correctly.
Standalone Driver Test
First, test the driver without a motor connected (safest approach).
Select Your Driver Type
3PWM BLDC Driver 6PWM BLDC Driver 2PWM Stepper Driver 4PWM Stepper Driver
// BLDCDriver3PWM(pwmA, pwmB, pwmC, (en optional))
BLDCDriver3PWM driver = BLDCDriver3PWM(TODO,TODO,TODO, TODO); // set your pins
  // enable more verbose output for debugging
  driver.voltage_power_supply = TODO;
  driver.voltage_limit = TODO;
  // driver init
  if (!driver.init()){
    Serial.println("Driver init failed!");
    return;
  // enable driver
  driver.enable();
  Serial.println("Driver ready!");
    // setting pwm
    // phase A: 3V
    // phase B: 6V
    // phase C: 5V
    driver.setPwm(3,6,5);
// BLDCDriver6PWM(pwmAh, pwmAl, pwmBh, pwmBl, pwmCh, pwmCl, (en optional))
BLDCDriver6PWM driver = BLDCDriver6PWM(TODO, TODO, TODO, TODO, TODO, TODO, TODO); // set your pins
  // dead_zone [0,1] - default 0.02f - 2%
  driver.dead_zone = 0.05f;
  // driver init
    return;
  // enable driver
  driver.enable();
    // setting pwm
    // phase A: 3V
    // phase B: 6V
    // phase C: 5V
// StepperDriver2PWM(pwm1, dir1, pwm2, dir2,(en1, en2 optional))
StepperDriver2PWM driver = StepperDriver2PWM(TODO, TODO, TODO, TODO, TODO, TODO); // set your pins
  // driver init
    return;
  // enable driver
  driver.enable();
    // setting pwm
    // phase A: 3V
    // phase B: 6V
    driver.setPwm(3,6);
// StepperDriver4PWM(ph1A, ph1B, ph2A, ph2B, (en1, en2 optional))
StepperDriver4PWM driver = StepperDriver4PWM(TODO, TODO, TODO, TODO, TODO, TODO); // set your pins
  // driver init
    return;
  // enable driver
  driver.enable();
    // setting pwm
    // phase A: 3V
    // phase B: 6V
    driver.setPwm(3,6);
Setup Steps
  1. Copy the code for your driver type
  2. Update pin numbers to match your setup:
    • implement TODOs in the code
    • PWM pins for each phase
    • Enable pin (optional but recommended)
  3. Set power supply voltage to match your hardware
  4. Upload and open Serial Monitor (115200 baud)
Verify Driver Initialization
βœ“ What to expect
You should see:
  • Driver ready! message in the serial terminal
  • PWM signals on all phase pins (even if no motor connected)
  • No Driver init failed! error
Check PWM Outputs
You can verify without a multimeter or by connecting small LEDs between each phase and ground. They should light up with different brightness levels.
If you connect LEDs you can do a quick test by changing the PWM values in the loop() function and observing the brightness change.
float angle = 0;
float set_voltage = 3; // Start at 3V
    // setting pwm
    angle = fmod(angle + 0.01, TWO_PI); // Rotate angle
    float pwmA = set_voltage*(sin(angle) + 1) / 2 ;              // Sinusoidal pattern for testing
    float pwmB = set_voltage*(sin(angle + TWO_PI/3) + 1) / 2 ;   // Phase shifted by 120 degrees
    float pwmC = set_voltage*(sin(angle + 2*TWO_PI/3) + 1) / 2 ; // Phase shifted by 240 degrees
    driver.setPwm(pwmA, pwmB, pwmC);
    delay(100);
Alternatively you could even connect your motor and observe it rotating, just make sure to set the voltage set_voltage to a very low value (e.g., 1V) to prevent damage.
Troubleshooting
Driver init failed?
  • Verify pin numbers match your hardware
  • Check power supply is connected and powered on
  • Ensure pins you’re using support PWM (check your MCU datasheet)
  • See Choosing PWM Pins guide
Wrong driver class selected?
Dead zone parameter?
  • Only needed for 6PWM drivers
  • Prevents overlapping phase switching; default is usually fine
  • Increase if you hear buzzing
Next Step
Once driver initializes successfully, proceed to
Motor + Driver Test
