PID Controller Implementation v2.4+
The PIDController class provides a discrete-time PID controller with anti-windup, output limiting, and rate limiting capabilities. It is used throughout SimpleFOC for velocity and current control loops.
Class Definition
From common/pid.h:
class PIDController {
    PIDController(float P, float I, float D, float ramp = NOT_SET,
                  float limit = NOT_SET, float sampling_time = NOT_SET);
    float operator() (float error);
    void reset();
    float P;              // Proportional gain
    float I;              // Integral gain
    float D;              // Derivative gain
    float output_ramp;    // Maximum speed of change of output value
    float limit;          // Maximum output value
    float Ts;             // Fixed sampling time (optional)
protected:
    float error_prev;     // Last tracking error value
    float output_prev;    // Last PID output value
    float integral_prev;  // Last integral component value
    unsigned long timestamp_prev; // Last execution timestamp
Constructor
PIDController::PIDController(float P, float I, float D, float ramp,
                             float limit, float sampling_time)
    : P(P)
    , I(I)
    , D(D)
    , output_ramp(ramp)     // output derivative limit [ex. volts/second]
    , limit(limit)          // output supply limit [ex. volts]
    , Ts(sampling_time)     // sampling time [seconds]
    , error_prev(0.0f)
    , output_prev(0.0f)
    , integral_prev(0.0f)
    timestamp_prev = _micros();
Parameters:
  • P: Proportional gain
  • I: Integral gain
  • D: Derivative gain
  • ramp: Maximum rate of change of output (units/second)
  • limit: Maximum absolute output value
  • sampling_time: Fixed time step (optional)
PID Algorithm
The operator() method calculates the control output:
float PIDController::operator() (float error) {
    // Initialize elapsed time with fixed sampling time Ts
    float dt = Ts;
    // If Ts not set, use adaptive sampling time
    if(!_isset(dt)){
        unsigned long timestamp_now = _micros();
        dt = (timestamp_now - timestamp_prev) * 1e-6f;
        // Quick fix for strange cases (micros overflow)
        if(dt <= 0 || dt > 0.5f) dt = 1e-3f;
        timestamp_prev = timestamp_now;
    // Proportional part: u_p = P * e(k)
    float proportional = P * error;
    // Tustin transform of integral part
    // u_ik = u_ik_1 + I*Ts/2*(e_k + e_k_1)
    float integral = integral_prev + I*dt*0.5f*(error + error_prev);
    // Antiwindup - limit the integral
    if(_isset(limit)) integral = _constrain(integral, -limit, limit);
    // Discrete derivative: u_dk = D(e_k - e_k_1)/Ts
    float derivative = D*(error - error_prev)/dt;
    // Sum all components
    float output = proportional + integral + derivative;
    // Antiwindup - limit the output
    if(_isset(limit)) output = _constrain(output, -limit, limit);
    // Output ramping (rate limiting)
    if(_isset(output_ramp) && output_ramp > 0){
        float output_rate = (output - output_prev)/dt;
        if (output_rate > output_ramp)
            output = output_prev + output_ramp*dt;
        else if (output_rate < -output_ramp)
            output = output_prev - output_ramp*dt;
    // Save for next iteration
    integral_prev = integral;
    output_prev = output;
    error_prev = error;
    return output;
Control Equation
The continuous-time PID equation:
\[u(t) = K_p e(t) + K_i \int_0^t e(\tau) d\tau + K_d \frac{de(t)}{dt}\]
Discrete Implementation
Proportional: \(u_p[k] = P \cdot e[k]\)
Integral (Tustin/Trapezoidal): \(u_i[k] = u_i[k-1] + \frac{I \cdot \Delta t}{2}(e[k] + e[k-1])\)
Derivative (Backward difference): \(u_d[k] = D \cdot \frac{e[k] - e[k-1]}{\Delta t}\)
Total output: \(u[k] = u_p[k] + u_i[k] + u_d[k]\)
Key Features
1. Tustin Integration
The integral term uses the Trapezoidal (Tustin) method instead of simple Euler:
Benefits:
  • Better numerical stability
  • More accurate for varying sample times
  • Reduced integration drift
  • Improved frequency response
Comparison with Euler:
  • Euler: \(u_i[k] = u_i[k-1] + I \cdot \Delta t \cdot e[k]\)
  • Tustin: \(u_i[k] = u_i[k-1] + \frac{I \cdot \Delta t}{2}(e[k] + e[k-1])\)
2. Anti-Windup
Integral windup occurs when the integral term accumulates beyond useful limits. SimpleFOC implements clamping anti-windup:
// Limit integral component
// Limit total output
How it works:
  1. Integral clamped to output limit
  2. Total output also clamped
  3. Prevents excessive overshoot
  4. Faster recovery from saturation
3. Output Rate Limiting
Constrains how fast the output can change:
Purpose:
  • Limits acceleration
  • Prevents sudden jumps
  • Smoother motor operation
  • Reduces mechanical stress
4. Adaptive Time Step
When Ts is not set:
if(dt <= 0 || dt > 0.5f) dt = 1e-3f;  // Safety check
Handles:
  • Variable execution rates
  • Micros() overflow
  • Missed cycles
Reset Function
void PIDController::reset() {
    integral_prev = 0.0f;
    output_prev = 0.0f;
    error_prev = 0.0f;
When to use:
  • Switching control modes
  • After long pauses
  • To clear accumulated error
  • Mode transitions
Usage in SimpleFOC
Velocity Control
// Configuration
motor.PID_velocity.I = 20.0;
motor.PID_velocity.D = 0.0;
motor.PID_velocity.output_ramp = 1000;  // [A/s] or [V/s]
motor.PID_velocity.limit = 12;          // [A] or [V]
// in FOCMotor.cpp move() function
current_sp = PID_velocity(target_velocity - shaft_velocity);
Position Control (P Controller)
// Typically only P gain used for position
motor.P_angle.P = 20.0;
motor.P_angle.I = 0.0;   // Usually zero
motor.P_angle.D = 0.0;   // Usually zero
motor.P_angle.limit = 0; // velocity_limit used instead
// Calculates velocity setpoint
shaft_velocity_sp = P_angle(target_angle - shaft_angle);
FOC Current Control
// Q-axis (torque) current
motor.PID_current_q.P = 5.0;
motor.PID_current_q.I = 300.0;
motor.PID_current_q.D = 0.0;
motor.PID_current_q.output_ramp = 0;
// D-axis (flux) current
motor.PID_current_d.P = 5.0;
motor.PID_current_d.I = 300.0;
motor.PID_current_d.D = 0.0;
motor.PID_current_d.output_ramp = 0;
motor.PID_current_d.limit = motor.voltage_limit;
// Usage in  FOCMotor.cpp - loopFOC() function
voltage.q = PID_current_q(current_sp - current.q);
voltage.d = PID_current_d(0 - current.d);  // d-current target = 0
DC Current Control
// in FOCMotor.cpp loopFOC() function
// Controls magnitude of current vector
voltage_magnitude = PID_current_q(current_sp - current_magnitude);
Quick Reference: Parameter Effects
Parameter Too Low Too High
P Slow response, steady-state error Overshoot, oscillation, instability
I Steady-state error Overshoot, oscillation, slow settling
D Allows overshoot Noise amplification, instability
output_ramp Jerky motion Slow response, sluggish
limit Output saturation issues No protection, potential damage
PID Tuning
For detailed tuning procedures and practical guidance, see the dedicated tuning guide:
PID Controller Tuning Guide Velocity Loop Tuning Guide
Motion control implementation Torque control implementation Low-pass filter implementation
