Sensorless control with the flux observer
FOC needs to know the rotor position. Usually it comes from a position sensor, but at higher speeds it can also be estimated from what the motor does electrically: a spinning motor generates a back-EMF whose angle follows the rotor. The MXLEMMINGObserverSensor from the SimpleFOCDrivers library does exactly that. It estimates the rotor angle from the measured phase currents, the applied voltages and the motor parameters, so you can run FOC without any position sensor.
The observer is ported from the MESC firmware by David Molony, and is also the default flux observer in the VESC firmware. The MESC documentation explains the maths behind it.
Source and README Full example project
When to use it
Sensorless control is a good fit when:
  • the motor runs mostly at medium to high speed: fans, pumps, propellers, wheels, spindles
  • there is no room for a sensor, or the sensor would be too expensive or unreliable (heat, dirt, vibration)
It is not a good fit when:
  • you need position control, holding torque at standstill, or smooth motion at very low speeds
  • the motor has to start under a heavy load
The reason is physical: at standstill and very low speed the back-EMF is close to zero, so there is almost nothing to estimate the angle from. Above a certain speed, which depends on the motor and on the quality of the current sensing, the estimate becomes reliable.
Observer as a sensor
In SimpleFOC, the observer is implemented as a Sensor. You link it to the motor with motor.linkSensor() like any other sensor, and the rest of your code stays the same.
Requirements
  • Current sensing: the observer only works with phase current measurements. Any current sense type works: inline, low-side or high-side.
  • FOC current control (TorqueControlType::foc_current) is recommended.
  • Motor parameters, all four are required:
Parameter Unit How to get it
Pole pairs - Datasheet, or count the magnets and divide by 2
Phase resistance Ω Datasheet, a multimeter measurement, or characteriseMotor()
Phase inductance H Datasheet or characteriseMotor()
KV rating rpm/V Datasheet, or measure it
The observer won’t produce an angle if any of these is missing. The accuracy of the estimate depends directly on how accurate they are, so it is worth measuring them rather than guessing.
Usage
#include <SimpleFOCDrivers.h>
#include "encoders/MXLEMMING_observer/MXLEMMINGObserverSensor.h"
// motor with all its parameters: pole pairs, phase resistance [Ω], KV [rpm/V], phase inductance [H]
BLDCMotor motor = BLDCMotor(11, 5.94, 100, 0.0005);
BLDCDriver3PWM driver = BLDCDriver3PWM(PWM_A, PWM_B, PWM_C, EN);
LowsideCurrentSense current_sense = LowsideCurrentSense(185.0f, CS_A, CS_B);
// the observer takes the motor, to read its parameters, voltages and currents
MXLEMMINGObserverSensor observer = MXLEMMINGObserverSensor(motor);
  motor.linkSensor(&observer);
  driver.voltage_power_supply = 20;
  // the observer gives the electrical angle directly, so no sensor alignment is needed
  motor.sensor_direction = Direction::CW;
  motor.zero_electric_angle = 0;
Setting sensor_direction and zero_electric_angle before initFOC() skips the usual alignment, which wouldn’t work anyway because the observer can’t measure the angle at standstill.
Set the motor parameters in the constructor
The observer calculates the motor flux linkage from the KV rating and the pole pairs once, when it is created. If you set motor.KV_rating later in setup(), the flux linkage stays at zero and the observer silently does nothing. Either give all the parameters in the BLDCMotor constructor, as above, or set the flux linkage yourself after changing the KV rating:
motor.KV_rating = 100;
observer.flux_linkage = 60 / (_SQRT3 * _PI * motor.KV_rating * motor.pole_pairs * 2);
Using characteriseMotor()
You can measure the resistance and inductance with characteriseMotor(), but note that the observer reads the inductance from motor.phase_inductance, while the characterisation stores it in motor.axis_inductance. Copy it over after the measurement:
motor.characteriseMotor(2.0f);                        // measures R and L
motor.phase_inductance = motor.axis_inductance.q;     // the observer uses phase_inductance
The KV rating still has to be known in advance, it can’t be measured this way.
Auto-tuning the current controller
Sensorless control depends on good current control even more than sensored control does. The observer estimates the angle from the measured currents and the applied voltages, so a noisy or oscillating current loop directly disturbs the angle estimate. And without a sensor, nothing corrects a bad angle estimate.
The good news is that the observer already needs the phase resistance and inductance, which is exactly what is needed to tune the current PI controllers automatically. tuneCurrentController() calculates the gains for a chosen bandwidth:
motor.tuneCurrentController(500.0f); // current loop bandwidth in Hz
It sets the P gain from the inductance and the I gain from the resistance, for both the q and d axes, and the current filters to 5 times the bandwidth. The resulting gains are printed to the serial monitor when debugging is enabled. If the resistance or inductance are not set, it runs characteriseMotor() first to measure them.
Choosing the bandwidth
The bandwidth must be well below the frequency of the FOC loop, i.e. how often loopFOC() is called. A good starting point is 5-10% of the loop frequency, for example 500Hz for a 10kHz loop.
Bandwidth Effect
Too low Slow current response, the torque lags behind changes and the motor can lose sync with the observer at high acceleration
Too high The current loop amplifies measurement noise, which makes the angle estimate noisy, and can oscillate
tuneCurrentController() only checks the bandwidth against the measured loop frequency once loopFOC() has run. When called in setup(), the loop frequency isn’t known yet, so choose the bandwidth carefully. If you’re unsure of your loop frequency, run the motor and call tuneCurrentController() again later, for example from a Commander command: it then refuses bandwidths higher than half the loop frequency.
Characterise, tune and save
Putting it together, the full parameter identification for a sensorless setup is:
motor.characteriseMotor(2.0f);                    // measure R and L
motor.phase_inductance = motor.axis_inductance.q; // for the observer, see above
motor.tuneCurrentController(500.0f);              // tune the current PIs
Measuring the motor on every startup is not necessary. Note the printed values once and put them in the BLDCMotor constructor, or save them with settings storage.
Read more about tuning the current loop
Starting the motor
Since the observer can’t see the rotor at standstill, the motor starts “blind”. In torque mode, a moderate target current is usually enough to get the motor spinning, after which the observer locks on and the control becomes smooth:
M0.5    apply 0.5A, the motor accelerates and the observer locks on
Some things that help with a reliable start:
  • Start with no load or a light load.
  • Give a high enough starting current, so the motor accelerates quickly through the low-speed range where the estimate is poor.
  • Use torque mode first. Switch to velocity mode once the motor runs well, and keep the velocity target above the speed where the observer is reliable.
Tuning and troubleshooting
Symptom Likely cause
Motor doesn’t move, the angle stays at 0 A motor parameter is missing, current sensing not linked, or the flux linkage is 0 (see the warning above)
Motor vibrates or stalls at start Starting current too low, or too much load at start
Motor runs but draws a lot of current / runs hot Wrong motor parameters, mostly resistance or KV. The estimated angle is off, so part of the current produces no torque
Motor runs rough at low speed but fine at high speed Expected: the back-EMF is too small at low speed. Increase the minimum operating speed
Audible noise, current oscillates Current controller not tuned, see auto-tuning the current controller
Unstable at high speed Current sensing too noisy or too slow, or the FOC loop too slow. Run loopFOC() as fast as possible
The observer has a few parameters you can adjust:
Parameter Description
flux_linkage Motor flux linkage, calculated from KV and pole pairs. Fine-tune it if the KV rating is not accurate
sensor_downsample Only update the observer every n-th call. Leave at 0 (every call) unless the MCU is too slow
Example project
For a complete project with hardware setup, see the sensorless FOC example using the SimpleFOCShield and an STM32 Nucleo board.
