CAN communication
Every SimpleFOC-microspora has a CAN transceiver and two daisy-chain connectors, so several boards can share one bus. See the hardware guide for wiring and the termination resistor.
Setting up the CAN commander
CAN uses the SimpleCANio library and the CANCommander from the SimpleFOCDrivers library. Each board needs a unique address on the bus.
#include "comms/can/CANCommander.h"
#include "SimpleCANio.h"
CANio can(PB8, PB9, NC, PC13);     // RX, TX, (not used), transceiver enable
CANCommander command_can(can, 15); // this board's address on the bus
  // ... motor setup
  command_can.init();
  command_can.addMotor(&motor);
  command_can.run();
The firmware uses a 1Mbps bus. With PlatformIO, add -D HAL_FDCAN_MODULE_ENABLED to your build flags (see toolchain setup).
CAN and the BOOT button
The CAN RX pin (PB8) is shared with the BOOT button. Pressing BOOT while CAN is running will disturb the bus.
Controlling the boards from a computer
The firmware repository includes Python CAN scripts built on pysimplefoc. Install the dependencies:
pip install pyserial rx python-can
pip install git+https://github.com/simplefoc/pysimplefoc.git
On Linux, bring up a USB-CAN adapter (e.g. CANable on /dev/ttyACM2) as a SocketCAN interface at 1Mbps:
sudo slcand -o -c -s6 /dev/ttyACM2 can0
sudo ip link set can0 type can bitrate 1000000
sudo ip link set can0 up
Then:
  • python can_scripts/scan_bus.py finds the boards on the bus
  • python can_scripts/move.py sends motion commands to a board
Back to writing the code
