β˜… Loading...
Registers, PacketCommander and telemetry
The communication modules of the SimpleFOCDrivers library are all built on one idea: registers. Every value of a motor that you might want to read or change has a register number: the target, the enable state, the angle and velocity, the PID gains, the limits, the measured currents and so on.
Once you can read and write registers, the channel doesn’t matter. The same register numbers are used by:
and by the Python library PySimpleFOC on the computer side.
Registers or Commander?
The Commander interface in the main library is simpler to start with and is what the web controller uses. The register-based protocols are better when a program, not a person, talks to the motor: they are compact, have a binary option, support multiple motors cleanly, and work the same over serial, CAN and I2C.
Registers
The most important registers:
ID Register Access Description
0x00 REG_STATUS read Motor status
0x01 REG_TARGET read/write Target, meaning depends on the control mode
0x04 REG_ENABLE read/write Enable or disable the motor
0x05 REG_CONTROL_MODE read/write Motion control mode (torque, velocity, angle, …)
0x06 REG_TORQUE_MODE read/write Torque control type (voltage, DC current, FOC current)
0x09 REG_ANGLE read Shaft angle
0x11 REG_VELOCITY read Shaft velocity
0x22 REG_CURRENT_Q read Q-axis current
0x30-0x35 REG_VEL_PID_P … REG_VEL_LPF_T read/write Velocity PID gains, limit, ramp and filter
0x36-0x3B REG_ANG_PID_P … REG_ANG_LPF_T read/write Angle PID gains, limit, ramp and filter
The complete list, with data types, is in the register reference. The authoritative definition is SimpleFOCRegisters.h.
PacketCommander
PacketCommander receives register reads and writes as packets, and sends back the responses. Combine it with TextIO for a human-readable ASCII protocol, or BinaryIO for a compact binary one.
#include <SimpleFOCDrivers.h>
#include "comms/streams/PacketCommander.h"
#include "comms/streams/TextIO.h"
TextIO comms = TextIO(Serial);
PacketCommander packetCommander = PacketCommander();
  // ... motor setup
  packetCommander.addMotor(&motor);
  packetCommander.echo = true; // respond to writes with the new value
  packetCommander.init(comms);
  packetCommander.run();
In ASCII mode, R followed by a register number reads a register, and R<reg>=<value> writes it. Register numbers are written in decimal, so REG_VELOCITY (0x11) is R17. Each packet ends with a newline:
R1=10.0     set the target to 10.0        -> r1=10.0000
R4=1        enable the motor              -> r4=1
R0          read the status register      -> r0=4   (4 = motor ready)
For a binary protocol, replace TextIO with BinaryIO. It is more compact and faster to parse, but not human-readable, so it is meant to be used from software such as PySimpleFOC.
Telemetry
Telemetry sends a chosen set of registers automatically at a regular rate, for monitoring and logging. It can include registers from several motors, and the register list can be changed at runtime.
#include "comms/telemetry/Telemetry.h"
TextIO io = TextIO(Serial);
Telemetry telemetry = Telemetry();
uint8_t telemetry_registers[] = { REG_TARGET, REG_ANGLE, REG_VELOCITY };
  // ... motor setup
  telemetry.addMotor(&motor);
  telemetry.setTelemetryRegisters(3, telemetry_registers);
  telemetry.downsample = 100; // send every 100th call of run(), 0 switches it off
  telemetry.init(io);
  telemetry.run();
The telemetry first sends a header packet describing the registers (e.g. H0=0:1,0:9,0:17: telemetry 0, registers 1, 9 and 17 (target, angle, velocity) of motor 0), followed by the data packets (e.g. T0=2.0000,17.0982,1.1026).
There are two variants for plotting tools, used the same way:
Class For
SimpleTelemetry The Arduino IDE Serial Plotter: values on one line, separated by tabs
TeleplotTelemetry The Teleplot extension for VS Code
Telemetry and PacketCommander can share the same TextIO or BinaryIO, so you can control the motor and receive the telemetry over one serial port. The telemetry itself can also be configured through registers (REG_TELEMETRY_REG, REG_TELEMETRY_DOWNSAMPLE, …).
New code
The telemetry is still marked as new and not fully tested in the library. Feedback on the forum is welcome.
Custom registers
You can add your own registers, for values specific to your application. Use register numbers from REG_CUSTOM_START (0xE0) and provide read and write handlers:
bool readMyValue(RegisterIO& io, FOCMotor* motor) {
  io << my_value;
  return true;
bool writeMyValue(RegisterIO& io, FOCMotor* motor) {
  io >> my_value;
  return true;
See the CAN page for registering them with the commander.
Communication sources on GitHub
