Calibrated sensor
CalibratedSensor is a wrapper around any SimpleFOC sensor that compensates the angle errors caused by an imperfectly placed magnet. It measures the error once, stores it in a lookup table (LUT), and corrects every reading from then on.
Originally implemented by @MarethyuPrefect, see the forum thread for the background.
Why calibrate?
Magnetic sensors measure the angle of a magnet on the motor shaft. If the magnet is not perfectly centred over the sensor, the measured angle is distorted: it runs a bit fast over part of the turn and a bit slow over the rest. As an example, a 0.5mm offset with a 3mm magnet can cause an angle error of around 10%.
For FOC, the angle error means the current is applied at the wrong electrical angle, which shows up as:
- torque ripple, the motor feels “notchy” when turned by hand in torque mode
- noise in velocity control, especially at low speeds
- reduced efficiency, part of the current produces no torque
CalibratedSensor doesn’t replace good mechanical alignment, but it removes most of the remaining error.
How it works
- The motor is turned slowly in open loop through several full turns, in both directions.
- At fixed electrical angles, the sensor reading is compared to the commanded angle.
- The differences are stored in a lookup table, 200 entries by default.
- During operation, every sensor reading is corrected by interpolating the LUT.
During calibration the motor must be able to turn freely through several full turns, ideally without load.
Usage
Set up and test your motor normally first. Only add the CalibratedSensor once everything works without it, so you can see the improvement.
#include <SimpleFOCDrivers.h>
#include "encoders/calibrated/CalibratedSensor.h"
MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, CS_PIN);
BLDCDriver3PWM driver = BLDCDriver3PWM(PWM_A, PWM_B, PWM_C, EN);
// wrap the real sensor
CalibratedSensor sensor_calibrated = CalibratedSensor(sensor);
motor.linkSensor(&sensor); // the real sensor is used during calibration
sensor_calibrated.voltage_calibration = 3; // voltage applied during calibration
sensor_calibrated.calibrate(motor); // turns the motor, builds the LUT
motor.linkSensor(&sensor_calibrated); // use the calibrated sensor from now on
The order matters: motor.init(), then calibrate(), then link the calibrated sensor, then motor.initFOC().
Calibration voltage
voltage_calibration is the voltage applied to turn the motor in open loop during calibration. It should be high enough for the motor to follow the commanded angle smoothly without skipping, but not so high that the motor heats up. The motor.voltage_sensor_align value is a good starting point.
LUT size
The constructor takes an optional LUT size, 200 entries by default:
CalibratedSensor sensor_calibrated = CalibratedSensor(sensor, 400);
A larger LUT captures finer errors, at the cost of memory (2 bytes per entry) and a longer calibration.
Skipping the calibration on startup
Calibrating on every startup takes a few seconds and turns the motor. Instead, you can calibrate once, print the result, and paste it into your code:
sensor_calibrated.printLUT(motor, Serial);
This prints the LUT, the zero electrical angle and the sensor direction, ready to copy:
uint16_t calibrationLut[200] = {32701, 32694, 32689, /* ... */ 32708};
float zero_electric_angle = 2.74;
Direction sensor_direction = Direction::CCW;
Then pass the LUT to the constructor, set the zero angle and direction on the motor, and don’t call calibrate():
CalibratedSensor sensor_calibrated = CalibratedSensor(sensor, 200, calibrationLut);
// ... sensor, driver and motor.init() as before
motor.zero_electric_angle = zero_electric_angle;
motor.sensor_direction = sensor_direction;
motor.initFOC(); // no alignment movement needed
Recalibrate after mechanical changes
The LUT is specific to the exact magnet position. If you remove the board, re-glue the magnet or change the motor, run the calibration again.
